Author Topic: Logrite Fetching Arch  (Read 4253 times)
Offline thekitz
  • wanna be logger & sawyer .......
« on: December 11, 2013, 01:17:31 PM »
Hello All - I'm in desperate need of any advice on LogRite Fetching Arch. My 3 local dealers have none in stock and I can't seem to justify buying one without seeing/touching it first. I'm in the Harrisburg, PA area if anyone might have experience with one ....... would love to see one at a tradeshow now that winter is here.  Thanks for any replies
Norwood Manual HD36 sawmill - Stihl MS391 - F250 Ford Super Crew cab - 16 foot 10k GVW trailer - Logrite Fetching Arch - 22 ton woodsplitter - best dog in the world to keep me company and discuss anything
Offline Jeff
  • Fearless Leader
  • Oh la di oh la da
    • Behind the  Forestry Forum YouTube channel
Re: Logrite Fetching Arch
« Reply #1 on: December 11, 2013, 02:03:59 PM »
I don't have a fetching arch, but I do have a mark7, that is no longer available as it morphed into the buck.  There are available video demos for the fetching arch. You need not worry one bit about the quality of the tool or the quality of the company and the people that make them. Call Tammy or Kevin and talk to them. Explain your application and they will let you know if it is the proper tool for your needs. They WILL NOT steer you wrong.
Offline thekitz
« Reply #2 on: December 11, 2013, 05:10:29 PM »
Thanks for the advice Jeff. I do trust that LogRite makes a quality American product. I will call Tammy or Kevin to chat with them.
Offline thecfarm
« Reply #3 on: December 11, 2013, 05:16:00 PM »
thekitz, welcome to the forum. I've seen them at shows,they are nice unit. What are you using it with? Have a sawmill too?
Offline thekitz
« Reply #4 on: December 11, 2013, 07:35:00 PM »
Hello thecfarm I have been tinkering around cutting firewood for 20+ years. With my wifes blessing, I just bought my sawmill - Norwood HD36 in September. I now have to think ahead of how to get these 16 foot logs out of the woods a little easier.
Offline beenthere
« Reply #5 on: December 11, 2013, 08:04:53 PM »
thekitz
Welcome from here too.
Is there a reason for taking out logs 16' long?
Maybe if building requires 16' like for joists and rafters, but 8' logs are much easier to handle in log form, when sawing the logs (yield), and when stacking lumber.
Offline Tam-i-am
  • Board Moderator
  • Gender: Female
    • Logrite
« Reply #6 on: December 12, 2013, 08:24:09 AM »
thekitz
the second closest  dealer to you is Penn-Holo in Schwenksville.  He doesn't stock the arches but this year he has sold quite a few.  He may be able to give you the name of his customers so you can call them or even pay them a visit.
Paul can be reached at 610-584-0877
Offline AnthonyW
  • Wannabe hobby sawyer
« Reply #7 on: December 13, 2013, 07:45:35 AM »
I have been wondering the same thing. Any dealers in southeast NH, northwest MA, or southwest ME have log arches in stock?
Any one in those areas readings that want to offer a demo of theirs? I'm thinking of the bucking arch. I'm concerned in real world usage with a 24" diameter 10' log that I won't be able to budge it by hand.
'97 Wood-Mizer LT25 All Manual with 15HP Kohler
Offline dgdrls
  • Learning the Art of Milling Logs
« Reply #8 on: January 06, 2014, 09:24:16 PM »
Good evening Anthony W.  I have a Buck arch, it will pick-up quite a bit.  I moved a bunch of 20"+ by 10' Hard Maple & Hickory logs with it,
Sound like you may want to go to the Fetching Arch just to add some capacity margin.
FWIW I purchased my at the Local WoodMizer shop.
DGDrls
Offline AnthonyW
« Reply #9 on: January 19, 2014, 08:26:53 AM »
DGDrls
I saw the video of the 60 pound son pulling the arch with a large log on it. Between that video and the others I think it is the way to go. In all of the videos I saw the arches were being used on flat (though not clear) ground. I didn't see any videos of anyone trying to pull the arch through the woods. Therein lies my concern.
Offline Jeff
  • Fearless Leader
  • Oh la di oh la da
« Reply #10 on: January 19, 2014, 10:35:59 AM »
Real life use. Mine is a mark 7, which became the buck.  The arches are in my mind, pretty indestructible,
Offline AnthonyW
« Reply #11 on: January 20, 2014, 06:02:12 AM »
I have no doubt they will pull through the woods with an ATV or tractor. My concern is using and pulling them by hand on terrain that is cover is sticks, branches, etc, and isn't flat. If a 60 pound kid can pull it on flat ground, does that translate to a full grown person being able to pull it over branches up hill? Please don't get me wrong. I believe the Logrite arches are quality built, but I need to know if they will suit my needs. I would like to see some real world videos of the arches in use by hand to convince me I should drop $1,200 on one.
Offline Jeff
  • Fearless Leader
  • Oh la di oh la da
« Reply #12 on: January 20, 2014, 07:51:46 AM »
Well. they don't have 4 wheel drive and they don't have anti gravity devices. So. depending on the branches and the size of the hill, the size of the load and the size and strength of the individual trying to pull it, your results may vary.  They work for many many people in many different situations, but they  may not work for you if your expectations out weigh the physics.
Offline John Mc
« Reply #13 on: January 21, 2014, 12:31:14 PM »
Yep, gravity can be a real bummer. If you can't push or pull your 1500# car up that slope, you're not going to be able to hand pull a 1500# log up it either, no matter how well made the arch is.
To give a rough idea (hopefully my trigonometry is correct):  If your wheels, bearings, surface were completely frictionless (zero rolling resistance), you'd have to exert about 130# of pull to move a 1500# log up a 5˚slope (almost 9% grade).  A 14˚ slope (about the equivalent of a 3:12 pitch roof) would take just over 360# of pull.  It gets significantly worse if you start taking into account the rolling resistance in the real world.
Basically, hand pulling is for relatively flat terrain, unless you are pulling lighter logs. If you get much slope, you need something other than human power to pull a good sized log. If an ATV or tractor is not in the cards, you may want to look at one of the small gas-powered winches.
Offline Tam-i-am
  • Board Moderator
  • Gender: Female
    • Logrite
« Reply #14 on: January 29, 2014, 12:40:59 PM »
AnthonyW  the Fetching arch was designed for steep slopes.  It is designed to be used with a winch line when using it on steep slopes.
The arches are great hand tools if the ground is relatively level.  The handle we sell with the fetching arch is called the two-man handle for a reason.  The capacity of the fetching arch is 2000 lbs.  And 2000 is still 2000 lbs whether it is on wheels or not.  On level ground like a lawn or trail on man could pull the loaded arch.  If the ground is rocky you can use that pumping action we describe in the Junior Arch video.
Depending where you are in New Hampshire, you could come for a visit and check one out.
Staging Logs with my LogRite Fetching Arch
Started by pnyberg on Sawmills and Milling
Last post September 08, 2009, 09:39:10 PM
by Don K
My fetching arch
Started by kelLOGg on Sawmills and Milling
Last post January 03, 2015, 04:57:13 PM
by kelLOGg
Log Rite Fetching Arch
Started by 123maxbars on Sawmills and Milling
Last post March 07, 2018, 12:20:46 PM
by Resonator
Upgraded my Fetching arch
Started by sprucebunny on LogRite Tools and Rite Leg Co
Last post September 20, 2011, 12:04:59 PM
by Tam-i-am
