Lt-40 mast rails
Started by drobertson, April 09, 2014, 09:46:10 PM
drobertson
Just wondering how many folks make adjustments to theirs, and how is the gap ratio between the front mast to back, and the back side of the mast to the front?  And the upper pads to the lower?  Not sure now if this makes any sense at all ;D
Chuck White
My manual is at the mill at this time.
I adjusted mine just a couple of weeks ago and the book says that clearance is to be checked when raised all the way up and when it's all the way down.
The clearance is the thickness of a business card!
Complete alignment instructions are in the owner/operators manual!
barbender
Quote from: Chuck White on April 10, 2014, 07:20:55 AM
X2
Nomad
WoodMizer LT50HDD51-WR
Lucas DSM23-19
scully
I looked at mine today and wondered about this ! I need to adjust !
I bleed orange  .
Brucer
I check mine every year, but I only need to adjust them every 3-4 years. Keeping the masts well lubricated will reduce wear.
Note that the adjustments should only be made with the saw head at the highest and lowest positions. The mast rails may bow apart slightly in the center so setting the clearances with the head partly raised could cause the head to bind when it's away from the center.
Follow the procedure in the manual -- it's critical to do things in the right sequence.
Bruce    LT40HDG28 bandsaw
