Author Topic: Truss construction  (Read 1125 times)
Offline Nate Surveyor
  • If you like work, you will always be happy!
Truss construction
« on: November 08, 2007, 11:13:11 PM »
Well, I have not been milling for a while.
Well, I am back at it now.
I have a bunch of wood cut now, and need to build trusses. I have designed simple trusses, and cut them out, and built them. But, it takes me a while.
But there should be some sort of web site that will allow you to plug in the numbers, and it will return all the angles and distances to cut it out.
Does anybody know of any such thing?
Thanks,
Nate
I know less than I used to.
Offline WH_Conley
  • I need to tide my profile!
    • Stone Hill Hardwoods
Bill
Re: Truss construction
« Reply #2 on: November 11, 2007, 09:44:41 PM »
Thanks Mr. Conley.
This will be helpful later. Right now, I am trying to make some smaller trusses, spanning 8', with all open space under, (no framing in the A part), and Then some larger ones like this. You wind up with an upper and a lower beam in it. I doubt I am using the correct terminology.
Essentially, I am doing a trial run with an 8' span, and then want to go bigger, with an OPEN space under the A of the truss.
Sort of like this:
http://www.chiefarchitect.com/support/displayfaq.php?faqNumber=68
Nate
A truss I like for affordable construction
Started by Don P on Timber Framing/Log construction
Last post November 18, 2007, 11:05:33 AM
by scsmith42
Sawmill Shed truss construction question
Started by mart on Sawmills and Milling
Last post August 05, 2020, 10:12:44 PM
by Don P
Hammerbeam truss construction and need for cable or buttress
Started by Farmer Jim on Timber Framing/Log construction
Last post April 01, 2016, 01:50:30 AM
by thechknhwk
clip
LSU Lap Nailed Truss
Started by Ohio_Bill on Sawmills and Milling
Last post February 04, 2014, 03:05:03 PM
by BCrabtree
