New mill on the way
Started by Osagedon, February 25, 2008, 06:36:39 PM
bedway
Did somebody say Pics??????,,,Where Where?,,, :) bedway
Osagedon
Bedway,
The mill is suppost to be at the Fed Ex loading dock tomorrow (Friday) at 9:00am.  Probably take good part of Sat. to get things figured out.  The pics are on the way hopfully this weekend sometime.  The box of bands I ordered showed up today, I ve been looking at them off and on all day.  They look pretty mean I'm sort of scared to uncoil one :D
Osagedon
bedway
Osagedon, make sure you wear gloves and eye protection when uncoiling them blades. Ive had em take hunks out of me on more than one occation. Would i be a little correct in thinking your a tad excited with anticipation of your mill arriveing? ;D,,bedway
Part_Timer
Enjoy the new machine.   Sawmill has been a great hobby and I've made a lot of freinds because of my mill purchase.  Make sure to wear safety gear and be safe.
Peterson 8" ATS.
Osagedon,this should take you to,coiling and uncoiling band blades.
https://forestryforum.com/board/index.php?topic=19157.msg275038#msg275038
Since you are new you may not know about the knowledge base.Go to the upper right,find
Forum Extras,
this will take you to,
Knowledge Base,
find Milling Bandmills,
than find
Lots of other infro in the knowledge base too.Look around,you will enjoy it.
Dan_Shade
Tom's knowledge base article on how to uncoil a band
there are some pictures here somewhere, it's not difficult at all after you learn the tricks, but if you don't know the tricks, they'll tear you a new one....
it's safest to learn how to do it using a lawnmower belt they won't cut you open or smack you quite as hard!
lots of dull bands and chains
zopi
Quote from: Dan_Shade on February 29, 2008, 09:59:57 AM
[it's safest to learn how to do it using a lawnmower belt they won't cut you open or smack you quite as hard!
but you learn faster with a band.... :D
Got Wood?
LT-15G GO chassis added.
WM sharpener and setter
And lots of junk.
beav39
cant wait to see you sawing    great little machine!!!!
sawdust in the blood
