help me decide
Started by Skioutty, July 24, 2016, 05:58:03 PM
Skioutty
So I have been doing enough cutting where my current MS280 is lacking, and I have decided to get a new saw. I've got it down to the following 2: A Sthil MS391 or a Sthil MS361. Either saw will have a 25 inch bar. The 391 is the top of the line Ranch / Farm line and the 361 is middle of the road Pro line. So what are your thoughts?
ladylake
MS361, built way better. And more power no matter what the specs say.  Steve
rburg
I would go 361. Lighter, better built, and more power.
kenskip1
The 391 has power but is like lugging around a boat anchor.
Stihl The One
Stihl Going Strong
Stihl Looking For The Fountain of Middle Age
DelawhereJoe
I was in your same spot, got a 362 c-m...not looking back. Shell out the money for the pro saw, lighter, more power, more metal parts.
Skioutty
Thanks for the quick replies.
& ooops my bad I typed 361 in stead of 362.
coppice
362 is a better saw than the 391 all around, and it feels much better in the hand than the 391 does, at least for me.
That said, and this might just be my preference, but I'd want a lot more saw than that for regular use with a 25" bar, particularly if you're going to be using all 25" of the bar while doing dynamic cutting - felling, cutting stuff that has stresses/binds on it (e.g. blowdowns), and other uses where you want to be able to "out cut" the wood before it sets to moving on you - rather than static cutting such as just cutting stacked-up logs on a pile.  The 362 platform seems like a great saw to hang an 18" bar off of, in keeping with the goal of keeping things in the 3:1 to 4:1 engine cc to bar length in inches range.  This isn't to say that it can't run a 25" bar, just that handling/balance will suffer and it will not be as enthusiastic in running that much bar as one might prefer a saw to be.
What bar/chain combo has the 280 been running?  Those saws (270 and 280) always seemed decent to me as 16" firewood/around the property type of saws, but did not really like wearing a 20" bar, especially when it was getting buried in hardwood.
DelawhereJoe
What size wood do you plan on cutting?
Skioutty
Quote from: coppice on July 24, 2016, 08:59:38 PM
Thanks for the post coppice.
I have no intentions of keeping the 25 inch bar buried in timber all the time, it's more like having the ability to get into a log then jump to the other side and keep my plane in the started cut. My 280 has an 18 inch bar on it and it is sometimes just too short to reach into and find the started slice. I do hear what you are saying about enough motor to keep the chain moving fast through timber that will pinch and bind if too slow. I just feel like moving up only 2 inches and spending 750 bucks to do it is not that much of an upgrade, I wish there was a 22 or 23 inch.
DelawhereJoe
You can pick up a 22" bar for your saw, Baileys online carries them, but unless you only buy the chain online or know someone that can make you loops of it, tractor supply is the only place I know to get 22" loops locally.
DelawhereJoe
Are you also hard set on Stihl?
Skioutty
Hmmmm, Bailey's.....I'll have a look, thanks.
Yup Sthil it is for me.
Ada Shaker
Definitely like the 362, though I don't know about a 25" bar on it though. If I were looking at a 25" bar I'd be looking at one of the 400 series saws that can run it without bogging it down. It's a more resonable step up from the 200 series and much more capable. If  I latter needed a bigger saw id always have a 600 or 800 series saw to step up to. Three saws would then cover all my needs as far as size were concerned.  Sometimes it also comes down to how much weight you wish to handle, in which case the 362 is a mighty fine saw IMHO.
If it hangs to the left, your likely to be a Husqvarna man.
If it hangs to the right, your likely to be a Stihl man.
Anything else is an uncomfortable compromise.
                             AND
Walking with one foot on either side of a barbed wire fence can become extremely uncomfortable at times.
DelawhereJoe
For about $100 more you could pick up an 80cc echo saw with a 24"-36" bar, it will be my next saw purchase when I want a bigger saw. I live on a budget or the 461 would be my next saw.
motohed
Buy the 362 and don't look back , with good care , it will last for years of service . You will end up with a 20" and 25" bar in the long run the small saw will be used for brush cutting and limbing at best .
Skioutty
I stopped by my local dealer and held the 391 and was not in love with it.
He currently did not have a MS362 for me to hold but tried to push a 261 on me.
I plan on stopping else where later in the week.
DelawhereJoe
The 261 is a great saw, I have an 026 thats been running for 20 years now. Its starting to get tired and is on my overhaul list but its my go to saw for small stuff, great with a 16" bar and full chisel chain.
Skioutty
I know it's a lesser saw than your 026 but that's the same way I feel about my 025 that I've owned for 22 years.
btulloh
I think when you hold the MS362 it will immediately feel better than the 391.  The 362 is worth the wait and the extra $$.  The pro saws are just better if you're in it for the long term.  Not that there's anything wrong with the F&R saws, they're just not as balanced or maintainable.  The difference is apparent just by picking them up.  Starting the saw really shows the difference.
If the 261 is big enough it's a great saw also.  Ideally, you should get both.  But that depends on whose paying.  ;) I've had an 026 for 20 years and with routine maintenance it's still going strong.  I wouldn't want to be without it because there's a lot always a lot of small work to do and I like the option of fitting the saw to the task.
HM126
Carson-saws
MS440 with a short bar and pro chain...and a tight grip!
Let the Forest be salvation long before it needs to be
Skioutty
I bought the 362c-m today and a couple of yellow chains.
I also got the 6 pack of the ultra to double the warranty.
Skioutty
Quote from: Carson-saws on July 26, 2016, 10:16:27 AM
I would have loved to get the 461 but it was a little too spendy!
DelawhereJoe
After around 5 tanks of fuel you will be very happy with the saw, loads of power over your current saw.
Skioutty
rburg
Be sure and let us know how you like it.
