Don't try this at home!!
Started by PAmizerman, June 07, 2019, 10:25:42 PM
PAmizerman
I've been happy with this strapping. It's pretty tough stuff ;D
Hydraulics everywhere
Woodmizer edger 26hp cat diesel
Traverse 6035 telehandler
Case 95xt skidloader
http://byrnemillwork.com/
WM bms250 sharpener
WM bmt250 setter
Ljohnsaw
 :o
Impressive.  What kind is it?  Did it stay stretched?
John Sawicky
Peter Drouin
Why not go under the thing with the forks? Someone is going to get hurt doing that.
A&P saw Mill LLC.
License NH softwood grader.
ladylake
PAmizerman
@Peter Drouin @ladylake this bundle was between a pile of logs and other slabs. I could not get under it with the forks. It was one of two bundles that we're seasoned. I needed it to put in my slab rack to cut for camp firewood. The machine tires never moved just the boom. I would NEVER even think about trying to load a customer like that. No one else was around. Once I got it lifted past the logs I set it down and went under it with the forks.
It was back in this hole.
Then moved to the cutting rack
WM bms250 sharpener
WM bmt250 setter
PAmizerman
@ljohnsaw I use 3/4" woven strapping with a 2500 lb break strength. I buy it from a company called
strapping products.com
It didn't stretch really the slabs just rolled up. Once I set it down the straps were not loose.
WM bms250 sharpener
WM bmt250 setter
Peter Drouin
A&P saw Mill LLC.
