Milling Cherry Lumber
Started by POSTON WIDEHEAD, August 21, 2013, 09:10:06 PM
POSTON WIDEHEAD
I do not saw a lot of Cherry......hardly ever.
I bought a 12 foot Cherry trunk for $38.00. It had 216 BF in it. I sawed it 5/4 x wide, no live edge.
Look in the first picture, there were 3 boards that had this in it. What caused it. It was not the blade, it looked like the wood was just pulled out of it.
The rest of the boards were perfectly smooth there after.  say_what
mesquite buckeye
My cherry frequently has radial cracks near the pith. Try not to get too pithed off though, it's still really pretty. ;D
POSTON WIDEHEAD
This was about 2 inches above the Pith.
Delawhere Jack
I believe the Latin term is, crackiusium mysteriusem.
Quote from: POSTONLT40HD on August 21, 2013, 09:10:06 PMLook in the first picture, there were 3 boards that had this in it. What caused it.
Don't worry, all Cherry has pith check.  In your instance the pith check crossed through those three boards.
Always measure and get the pith check an equal distance from the sawmill bed before you saw through.  In the above picture the pith check was contained within two boards.
The good thing was that the "other" side of both boards were clear and free of visible defects.   ;D
Delawhere Jack
Quote from: Magicman on August 21, 2013, 09:35:24 PM
Or maybe what MM said....   :)
Quote from: Delawhere Jack on August 21, 2013, 09:34:49 PM
I like what you said, better  :D.  That surely explains it if you understand Latin.
POSTON WIDEHEAD
I told you in another thread.....never mess with a crackiusium when you don't know what to expect.  :)
 :D
That is right.  You did not follow your own advice, but then again, cherry will make you crazy  ;D.
drobertson
Not bad for an 18' log! man what a job that must have been to retrieve that much footage!  8)    david
POSTON WIDEHEAD
Quote from: drobertson on August 21, 2013, 09:49:38 PM
I had a typo I corrected in my opening post. It was a 12 foot log. I sawed it in to 2 /  6 foot logs. Originally I said a 12" log.
drobertson
