Kohler RPMs
Started by POSTON WIDEHEAD, September 11, 2014, 08:08:39 PM
Peter Drouin
Dose the place where you got your spring have engines where you can look at to see where the spring goes?
A&P saw Mill LLC.
License NH softwood grader.
Compensation
Quote from: hamish on September 11, 2014, 08:15:10 PM
Koler 29G doesn't exist!
It was built just for him. Stands for 29 goat power
D4D caterpillar, lt10 Woodmizer, 8x12 solar kiln, enough Stihl's to make my garages smell like their factory :) Ohh and built Ford tough baby!
sawguy21
If you have it in the outermost hole it will speed the engine up but will not respond as quickly to load changes. Moving the spring in will make the governor more sensitive but too much will cause surging or 'hunting'.
POSTON WIDEHEAD
Quote from: Compensation on September 11, 2014, 10:35:42 PM
I like that ........ :D
Tee
Poston, I see there still giving you a hard time.
POSTON WIDEHEAD
Quote from: Tee on September 12, 2014, 09:39:52 AM
I get no respect. Red headed step child!  :D Good crowd though.
Sixacresand
That $2 spring is changing the metabolism of the whole operation: faster sawing, faster stacking, longer naps,etc.   :D
JohnM
Quote from: POSTONLT40HD on September 12, 2014, 09:45:18 AM
You're the Roddy Dangerfield of the Bovidae family.  ;) ;D
Lucas 830 w/ slabber; Kubota L3710; Wallenstein logging winch; Split-fire splitter; Stihl 036; Jonsered 2150
DMcCoy
I'm stuck on them allowing you to shoot deer next to bait.  You must have an infestation.
Isn't there some wear next to the hole you were using?
Busy Beaver Lumber
Quote from: Peter Drouin on September 11, 2014, 09:11:24 PM
Call WM and ask what hole to put it in. Then mark it ;D
I can hear this phone call now, and the laughter in the background
Receptionist: " I have Dave on the phone and he would like to know what hole to put it in!"  :D
Woodmizer LT-10 10hp
6 x 10 dump trailer
Grizzly 6in Spiral Cut Joiner
Twister Firewood Bundler
Jet 10-20 Drum Sander
Jet Bandsaw
Save a tree...eat a beaver!
Quote from: DMcCoy on September 13, 2014, 07:10:45 AM
The bag limit here in Georgia is 12 per season, only two can be antlered, though.
rooster 58
Sounds like Dave took up golfin' ;D
DMcCoy
Quote from: WDH on September 13, 2014, 07:16:54 AM
They are obviously trying to reduce numbers with 10 does.  Every hunter must be sick of eating venison.  Does the meat marble if you feed them corn?
QuoteDoes the meat marble if you feed them corn?
nope, stays very lean with no fat in the muscle, but only in between.
POSTON WIDEHEAD
Talked to Kohler. The spring goes in the 3rd hole on my 29G.
Back to normal.  :)
red
barbender
Ok,I got the "normal" part now.  ;D
There is nothing normal about this.
Sixacresand
When my Kohler on my mill won't rev up, I will remember that corn can be bought in 800 lb bags.   :D
POSTON WIDEHEAD
Quote from: Sixacresand on September 14, 2014, 09:14:11 AM
Ain't life grand!  :D :D :D
backwoods sawyer
Quote from: POSTONLT40HD on September 14, 2014, 12:21:55 PM
800lb of corn will give an ole goat a belly ache ;D
Backwoods Custom Milling Inc.
Down here, if you had 800 pounds of corn, you would make liquor  ;D.
POSTON WIDEHEAD
Quote from: WDH on September 14, 2014, 07:53:24 PM
Well....I wasn't gonna say it.  ::)
backwoods sawyer
Wellll... he is still going to get a belly ache :D :D
Ever been the leaning post while walking a horse that has been given three doses of loopy med's to beable to float its teeth.
Don't expect an~ole Goat~would walk much straighter~~~~~~
