Howdy
Started by cntryby, July 10, 2011, 10:56:31 AM
cntryby
I looked but didn't didn't see an introduction category, if I missed it you'll just have to harass me.  :D
Names Brad, my brother & I have been looking for a mill for a while. We have considered building one, but are in one of those catch 22 deals where we need a building, to work in but need the mill to supply the lumber for the building.
I've read so much here I have a head ache. I'm interested in anything from an EZ boardwalk 40 to Cooks MP32 to Timberking 1400 to Woodmizer LT28.
I know... I know... Big price range & ability difference.
We have a small bit of property with lots of good pine, where we live, with access to all the equipment we need to handle the logs. But we also have a place approximately 6 hours away that we need to do quite a bit of work at too. Which makes the mills with hydraulics very attractive. Adding a valve & cylinders to the existing circuits of the TK shouldn't be to difficult.
Most of the lumber will be in the 8 to 12 foot range but there will be times we'll need to cut 20 + feet. Adding length to any of the mills will be pretty simple, with the exception WM.
I'm sure as we work through this & get into milling, I'll probably be asking for some "hands on" with someone to help educate me on the milling process.
Anyway. thanks for all the great info on here, look forward to hearing more & more.
Any thoughts on my dilemmas, things I should consider?
Grey haired riders didn't get that way from pure luck.
metalspinner
Welcome aboard, cntryby!  :)
Buy bigger than you think you will need.  Your money will go farther in the used market and there should be no shortage of good options there.
Texas Ranger
Welcome to the board, country boy, there will be a lot of help here in just a little bit, pull up a stump and rest a spell.
ellmoe
Welcome aboard! I second MS, look at used.
Dan_Shade
How much volume do you think you'll cut?
I like my hydraulics, they make things faster, and are easy on my back.
lots of dull bands and chains
cntryby
Thanks guys.  ;D
Off the top of my head, things that would seem important.
Wheel size. (18" min.)
Engine size. (25 HP min.)
Rigid, durable frame.
Cut / throat size. (32" logs min)
Quality engine.
What else?
I have know idea on the volume. It will mostly be used for personal use, but that will be a great deal more than the average Joe.
It wouldn't hurt my feelings to make some $$ on the side as well.
One thing I keep thinking about is, I'm 44 & my brothers older than me. I don't mind working & can work most kids into the ground pretty easy... but... how much longer will that last. Why work so hard & physical?
I've been looking for a used mill for 4 or 5 years. Everything I think is a fair price is beat all ta &%$&^.
redbeard
Welcome, you guys have a good plan, something to consider is a sharpener & setter you could get alot more milage out of the bands. Blade and sharpening costs will be your biggest exspence. Good luck with your building & milling adventures.
fishpharmer
Welcome to FF cntryby.   Look at and operate all the different kinds of mills you can find before deciding.  Lots of good used equipment out there now.
Lucas 618 with 50" slabber
Deere 5065E mfwd w/553 loader
cntryby
Quote from: fishpharmer on July 10, 2011, 11:43:15 AM
Thanks for the welcome!
Where are they cause apparently I don't know where to look.  :( :-[
fishpharmer
I just sent you a pm.
You will find mills right here on The Forestry Forum as folks retire or upgrade.
Extending the length of any portable mill, that is on a trailer, is going to be a handful.  All of the "manual" or minimally hydraulic/electric assisted mills that lie on the ground, are the easiest to extend because there is no connection  of the head of the mill to the bed of the mill, other than the wheels. Just add extensions for the wheels to run on.  I've often thought of that as a benefit to having a ground-mounted push mill as a second mill, even if you upgrade to the most fancy mill available.
Welcome aboard the board board!  Where'bouts in SW Ga are you?  I'm pretty DanG close to there, and always like meeting new folks. :)
I remember several years ago, a new member came in with a first post almost identical to yours, and I responded with just about the same welcome message.  About 3 days later, he was down here sawing on my mill, then about 3 months later, I was up there sawing on his new mill.   Needless to say, we have become good friends along the way. :)  Calls himself Brdmkr, he does.
cntryby
Quote from: DanG on July 10, 2011, 01:36:41 PM
Not far from Columbus.
Matter of fact, I might wanna test drive your mill too, if that's OK. I've used a couple, an older Woodmizer early90's, & one similar to a Hudson but I'm not sure of the brand. The fella who own the WM didn't maintain it at all, including leaving it out in the weather without so much as a cover. I made a few wavy boards.
The manual push I used was OK & seem to cut true. I actually could "feel" tension / resistance while cutting, which could be an advantage.
I think I'm leaning more towards the Cooks, but.... still undecided.
Welcome cntryby, to the Forestry Forum.  I would suggest actually watching the various sawmills operate before buying.  There is a difference.  I read that you have been looking at used, but I would not quit looking.  There are some dandy used ones out there.  I bought mine used 10 years ago.
cntryby
I've been to several farm expo's and spent days watching the various mills.
I like the Bakers & Timberkings but they seem to be on the higher end of the price scale.
I've kept an eye on our farmers bulletin, craigslist, local papers, E-bay, sawmill exchange, here... & more. What I'm finding is these things seem to hold there value very well. So If I'm gonna pay close to new, I would just as soon buy new & know that it's been maintain properly. However, if the right price on a good used mill comes up then I would not be opposed to it at all!.
LPitt
Welcome cntryby, good to see another Ga boy here. Know what you mean about building a mill. I built mine several years ago and while it was very rewarding it also was a lot of work and took me quite some time. Keep us updated.
Linn Lumber 1900 hyd, Bobcat T190 with grapple ect., Kubota MX 5100, Ford 555E backhoe, Sthil ms460, home made wood splitter, and more projects than I can count.
customsawyer
Welcome to the forum. I am about 2 hours east of you. You can come run both of my LT70s and I will sit in the shade and watch. ;D
www.thecustomsawyer.com
millwright
Hi and welcome to FF  I recently upgraded  from an lt30 toan Lt 35 with hydraulics and the difference in labor required is a big factor  I usually work alone so anything to make it easier helps I also looked for a used mill but found out they hold their value so well that I might as well buy new. Good luck in your search.
argyle1
there's usually some mills for sale on "sawmill exchange" as well
brdmkr
I resemble that remark!  DanG's memory is pretty good.  Welcome to the forum.  If you would like to test drive a Lucas mill, I would be happy to oblige.
Lucas 618  Mahindra 4110, FEL and pallet forks, some cant hooks, and a dose of want-to
Cntryby,
If you get over near Perry, come and see me and I can you show you a small operation  :D.
BirdMarker,
How is that kiln doing?
Meadows Miller
Gday
Welcome to The Forum Country Boy  ;) ;D ;D 8) 8)
With Mills theres a fair range to chose from out the from New and Used and different styles and production rates Like Board maker and like most every one else here Im happy with mine  ;)Ill be in GA  in late August With a new 10-30 Lucas If you want me to show you what they are capable off  ;) ;D ;D 8) 8)
Regards Chris
4TH Generation Timbergetter
cntryby
Well, I thought I had found a mill. We agreed on a price arranged to meet so I could saw a few boards, I pulled the cash outta the bank, paid a few minor expenses in preparation for a 12 hour round trip to go check it out & make the deal.
Offered to wire earnest money... etc etc. "No need.. if your say your coming it'll be here wait'n for ya."
He lied, waited till the day for me to leave and emailed me he sold it.
Meadows Miller
You gotta love that there is some idiots out there Mate  ??? :) :) :( :( >:( >:(
Quote from: cntryby on July 12, 2011, 07:33:31 PM
That may not be the only lie that he told you.   :-\
