Might be overthinking...
Started by Nebraska, August 16, 2020, 10:18:53 PM
Nebraska
Working on a new porch ceiling, replacing some sagging grooved masonite (instead of using correct fasteners and tacking it up right to fix) wife said you have a sawmill, you can make something  cool. How about some rustic boards. This validated  the sawmill :).  Fast forward I have 450 ish board feet of 9.25" rough sawn, air dried, Green Ash on my porch that I'm finishing with a coat of tung oil/turpentine, and  after it's cured  a coat of poly on top. It was treated with solubor off of the mill green and edges and ends were treated after edging and squaring up ends. Dead stacked first batch it was 48 hrs after application and started coating the next 20 boards.
My question is?..... Should I have restickered the first batch of boards?  It still felt  just a little slick earlier when I stacked. So now I'm stewing on it and I don't know the answer. Stickered it takes a bunch more space out there.  Don't know if it would heat up as well...
