SPACE AVAILABLE
SPACE AVAILABLE
Author Topic: 16 gpm hyd. pump  (Read 791 times)
Offline 47sawdust
16 gpm hyd. pump
« on: November 26, 2020, 12:27:51 PM »
Looking for a reccomendation on a 16 gpm pump.
Mick
Mick
Offline Southside
    • White Oak Meadows
Re: 16 gpm hyd. pump
« Reply #1 on: November 26, 2020, 01:59:42 PM »
Have you tried Surplus Center?
White Oak Meadows
Offline hedgerow
« Reply #2 on: November 26, 2020, 02:38:06 PM »
Another vote for Surplus Center in Lincoln Ne. I run the MTE brand of two stage pumps and they have been good.
Offline 47sawdust
« Reply #3 on: November 26, 2020, 03:23:36 PM »
Yes, I have been looking at Surplus Center.
I'm not familiar enough to know what brand is preferable.
My experience with SC has been very good in the past.
Mick
Offline doc henderson
« Reply #4 on: November 26, 2020, 06:38:52 PM »
can also check with splitez and ask for James.  they have a basic website.  tell him doc from the forestry forum sent you.
Offline sawguy21
« Reply #5 on: November 26, 2020, 07:21:49 PM »
What is the application? If it is a home use log splitter an offshore unit from HF or a surplus center should meet your needs. If a more demanding use a Vickers or something similar from a farm/industrial supplier might be worth looking at.
Offline jmur1
  • Wood is King
« Reply #6 on: November 27, 2020, 12:58:27 AM »
I did buy this 22 GPM and they make a 16 as well:
Two Stage 22 GPM Log Splitter Pump | Log Splitter Pumps | Flowfit
It was quite inexpensive and did split alot of wood.
$216 Canadian worked quite well.  I dont see them on Ebay anymore (edit they are on Ebay UK)but you may come across them in other stores - just thought I would mention them.
Only drawback I found was the output shaft size was quite small.  I actually started to wear in the connector when not aligned and then started to heat.  I think if you avoid misalignment all wound be good.
jmur1
Easy does it
Offline woodworker9
    • Elite Concrete Raising Co.
« Reply #7 on: November 27, 2020, 10:20:36 AM »
Along these same lines, what do the better commercial splitter companies use for brands of pumps?  Speaking for myself, I don't buy "offshore" stuff when I can avoid it, regardless of cost.  It's just my way.  I'm a big fan of doing things as best I can the first time around.
03' LT40HD25 Kohler hydraulic w/ accuset
MS 441, MS 290, New Holland L185
« Reply #8 on: November 27, 2020, 02:03:50 PM »
concentric barns is better brand, some feel the over seas stuff is ok, poss made in the same factory.
Offline mike_belben
  • Pulp Friction
« Reply #9 on: November 28, 2020, 08:51:32 PM »
Eaton, danfoss sauer, charlynn, bosch rexroth, parker, muncie power products, marzocchi...
Revelation 13:11-18
SPACE AVAILABLE
