Author Topic: Not the Pump  (Read 2027 times)
Offline Magicman
  • A "Traveling Man"
    • Knothole Sawmill
Not the Pump
« on: October 05, 2015, 06:23:17 PM »
While sawing I noticed that the clamp seemed slow.  Maybe my imagination but I will look closer next time.  Yup, slower, so how about the loader?  Yup, much slower, but the hydraulic motors were rebuilt last year.  Open the cover and sure enough, hydraulic fluid coming out or the non-working pump.
No voltage from the solenoid to the pump, so I go to the toolbox for a replacement solenoid.
It was a relatively quick fix.  New solenoid and the pump is drawing ~90 amps.
The customer is impressed and we finished sawing the job.   ;D
Offline POSTON WIDEHEAD
  • Getting old but doing it with Friends.
Re: Not the Pump
« Reply #1 on: October 05, 2015, 06:34:11 PM »
I'm glad someone else knows how I felt the other week.  :D
Glad you're up and running Lynn. :)
Online YellowHammer
  • Sawing is fun for the first couple million boards.
    • Hobby Hardwood Alabama
Re: Not the Pump
« Reply #2 on: October 05, 2015, 11:37:27 PM »
Magic,
You are a sawmill fixing machine!  Especially with the customer breathing down your neck, which even makes it more difficult.
YellowHammerisms:
Take steps to save steps.
If it wont roll, its not a log; its still a tree.  Sawmills cut logs, not trees.
Kiln drying wood: When the cookies are burned, theyre burned, and you cant fix them.  So dont burn the cookies.
Sawing is fun for the first couple hundred boards.
Offline Magicman
  • A "Traveling Man"
    • Knothole Sawmill
Re: Not the Pump
« Reply #3 on: October 06, 2015, 08:59:11 AM »
During these years of sawing, I have pulled off several "fixes" such as this with the customer watching.  I take advantage of the situation and impress upon them that they not only hired the sawyer that would produce the best lumber, but also one that knows his sawmill inside and out and knows how to analyze and keep the sawmill in tip top shape.
That is taking a breakdown and turning it into an advertising situation.  If you are gonna blow a horn, it might as well be your own.   :)
Offline Jemclimber
Re: Not the Pump
« Reply #4 on: October 06, 2015, 10:48:59 AM »
Thanks for sharing the many scenarios and fixes you encounter. Lots of people read and learn without ever saying anything, myself often being in this category.
lt15
Offline canadianwoodworks
Re: Not the Pump
« Reply #5 on: October 06, 2015, 11:07:49 AM »
Nice fix, feels good to get it fixed, understand what's going on then keep on milling!
Offline Seaman
  • Still learning as hard as I can go.
    • Uniquewoodcuts.com
Re: Not the Pump
« Reply #6 on: October 07, 2015, 07:04:22 AM »
MM, nice fix ! Have you posted a list of the spare parts you carry to the job with you? Being new at this I would love to see it .
Thanks, Frank
Lucas dedicated slabber
Woodmizer LT40HD
John Deere 5310 W/ FEL
Semper Fi
Offline hackberry jake
Re: Not the Pump
« Reply #7 on: October 07, 2015, 07:17:29 AM »
I purchased a similar volt meter last week to use at work. It was $5 at the local hardware store in the discount bin. I have a $200 Fluke I use at home, but the little cheapie gets the job done and it hasn't walked off yet.
Offline slider
  • sawyer,trucker,tree service
Re: Not the Pump
« Reply #8 on: October 07, 2015, 07:18:14 AM »
I just go to Custom sawyers when i need a part quick. It's closer than Newnan and i can always weasel him out of a free beer.
al glenn
Offline Magicman
  • A "Traveling Man"
    • Knothole Sawmill
Re: Not the Pump
« Reply #9 on: October 07, 2015, 07:47:20 AM »
I carry very few spare parts, but that solenoid is a must.  I also have a microswitch for the hydraulics, a couple of blade guide rollers, and a repair kit for the blade guide motor.  There are probably a few other odds & ends, but nothing major.
Offline Sixacresand
Re: Not the Pump
« Reply #10 on: October 07, 2015, 09:35:28 AM »
Good job, MM.  If it had been me, I probably would have limped back to the house and called WM to tell me what to do.  Or call MagicMan.
"Sometimes you can make more hay with less equipment if you just use your head."  Tom, Forestry Forum
Diesel Primary pump from tank to injector pump
Started by Ironwood on General Board
Last post January 25, 2005, 08:12:11 PM
by Ironwood
How big should my pump be?
Started by CX3 on Forestry and Logging
Last post September 25, 2010, 08:28:53 PM
by madmari
Enough pump??
Started by overclocking on Firewood and Wood Heating
Last post February 16, 2016, 10:19:02 AM
by overclocking
16 gpm hyd. pump
Started by 47sawdust on Firewood and Wood Heating
Last post November 28, 2020, 08:51:32 PM
by mike_belben
