Squash died unexpectedly
Started by VB-Milling, July 13, 2021, 07:07:58 AM
VB-Milling
Wondering if squash isn't a good candidate to be planted in an elevated planter box. Everything else we have is doing great. Zucchini, potatoes and a bunch of herbs.
The squash was flowering, huge leaves and looking full of life a week ago. Been in steady decline ever since. Everything was transplanted from 4inch pots from the garden center on 21 May.
Looking pretty good on the right side of this picture.
All we got was one tiny squash about 4 inches.
Anybody have any tips?
HM126
Southside
Any beetles on the leaves or white fungus at the base of the plant?
nativewolf
Quote from: Southside on July 13, 2021, 07:31:08 AM
Good questions.  Also take a look at the stem as it enters the soil, any slits?  Can you take a stem and slice it open.
Liking Walnut
bannerd
Honestly it would be hard for zucchini to grow in such a small box.  Zucchini needs about three feet from other zucchinis to really thrive.  Without the spacing it encourages fungus.  You can combat the fungus and the beetles with neem oil (1tbsp to 1 gallon water 1tbsp of dawn dish soap or peppermint oil - white wash).  I've seen zucchini grow anywhere but it's just a bad technique.  Also, if you have pea stone I would mix that into the soil, the minerals from the stone will help the zucchini grow, will help with water to the roots and also deter moles/voles from eating the roots.
btulloh
Good advice above. I don't have any experience with squash in a container but they do need room and good drainage. I always planted in hills three feet apart.
Main problem here was squash borers but not hard to control. Nativewolf covered those symptoms but just from the picture yours don't look like squash borer damage. I suspect overcrowding and wet roots led to their demise. Look for fungus on the roots.
Maybe somebody with experience with container squash will see this and weigh in on techniques.
Sorry to see you lose your squash.
HM126
VB-Milling
Quote from: Southside on July 13, 2021, 07:31:08 AMAny beetles on the leaves or white fungus at the base of the plant?
Never saw any beetles and there aren't any now.  No fungus that we can see now and none that I remember.
Quote from: nativewolf on July 13, 2021, 07:55:10 AMGood questions.  Also take a look at the stem as it enters the soil, any slits?  Can you take a stem and slice it open.
Yes, there are slits.  See pics.
HM126
VB-Milling
Quote from: bannerd on July 13, 2021, 08:24:02 AM
That's what we thought too about it being in a planter box.  I guess because it was doing so well, we were hopeful.  Can't see any fungus though, so that leaves us a bit confused.  We will look into the pea stone.  Thank you.
HM126
btulloh
Squash borer. Must be controlled early when the plants are just a few inches tall. I always used Sevin dust at the base of the plant and on the ground. Reapply after a week or a little less. No doubt there are other ways to control as well.
HM126
VB-Milling
Quote from: btulloh on July 13, 2021, 08:43:02 AM
Its a bit of a bummer Bob, but we're pretty new gardeners so we'll chalk it up to "growing" pains. LOL
As far as drainage goes, the soil is contained in a crate lined with landscape fabric and open to the air on the bottom.  We usually water until water starts coming out the bottom....maybe 30 seconds worth.
HM126
VB-Milling
Quote from: btulloh on July 13, 2021, 09:03:27 AM
Is that what the slits indicate?
HM126
btulloh
Yes. The larvae eat their way in at the base of the stems then hang out and eat as they grow. Pretty soon all channels for water and nutrients are cut off from the rest of the plant.
HM126
VB-Milling
Quote from: btulloh on July 13, 2021, 09:16:05 AM
Just found this guy after rooting around a bit in the deadfall.  Is this a squash borer?
HM126
bannerd
Hard telling, either way something your probably don't want ;D
bannerd
You can split the squash stem, they usually hang out in there.
VB-Milling
Thanks everyone for your help!  I built all the planter boxes and my wife heads up the gardening department.  We were at a loss when it declined so quickly.  I knew exactly where to go to get the answers I needed!
Quote from: bannerd on July 13, 2021, 09:32:40 AM
I looked in a few and didn't see any.  Oh well.  I'll remove the offending crates.
Thanks again.
HM126
VB-Milling
Found them!  I understand now about how they block off nutrients in the stem.  Good knowledge.  We really thought it was because they were confined to the crates or a problem with sun/shade/watering.  I think we'll give it another go next season in the crates, but with the proper treatment for pests.  If they die again, we'll spread them out.  I guess I could always build a bigger planter box LOL
Thanks all!
HM126
btulloh
Good deal. Mystery solved. Plenty of info out there about controlling. Timing is the key to that.
You'll need some bigger boxes. Need some room for the squash to sit. Tag says 2 seeds, 6ft apart, just as a refer. Maybe some wings on existing box.  Need some info from someone who's done container squash.
HM126
bannerd
Not sure if you're organic or not but a dustin-mizer with the scoop inverted works very well to control the beetle.  We just invert the nozzle and it coats the underside of the leaves with DE.  The larva gets implanted there and eventually works its way to the bottom.  99% of the time the larva with diatomaceous earth dries out the larva.  If it's pre-existing(DE) on the plant the beetle typically moves on.. chicken food eventually or bat food I suppose.
Because the mizer can get under it.. I found even after a good rain it still holds on.
Southside
Gotta get some Chickens.   ;D
I have one of those dustin-mizers. They have been around for over 30 years because my great uncle had one back in the 80's. His was just like mine. You can get those at places that sell the diatomaceous earth. Lee Valley used to sell them a few years ago, not now.
VB-Milling
Ok so I definitely had to Google what the heck a Dustin-mizer was, so now I get it.  We have a very limited garden so I think I'll go with something like @btulloh recommended.
Its funny...I grew up in CT and I remember my mother planting a 12x15ft garden every year and doing nothing more than watering it 4 times a week and we'd have more veggies than us and our immediate neighbors could ever eat.  Either I mentally blocked out the beetles, borers, caterpillars, and all the other pests, or things are just different because of the growing conditions there versus southeastern VA.
HM126
21incher
I have been growing  squash squeezed into  small raised beds for years with fantastic results. I just use compost.  After a while I pray for borers  ;D.
VB-Milling
Quote from: 21incher on July 13, 2021, 04:15:16 PM
I was really hoping you were going to chime in @21incher
I remember seeing some raised beds in your videos.
HM126
Mooseherder
I've got a garter snake hanging out at the garden.  He's there everyday hopefully eating bugs.  Got the first flower yesterday.  :)
21incher
I have switched from a large open garden to raised beds and it was the best move I have ever made. The only secret  is to keep a good compost  bed going and refresh them every spring. Bugs are a gardeners worst problem and it's  easy to pick bugs from one bed at a time and plant a little  extra for them. Not to late to replant them in most areas as they usually  take 45 to 55 days. Good luck.
btulloh
More important when you apply something than how. The borers wouldn't bother you if you replanted now. I think around here the danger time is June. Once their life cycle  is complete you're not in harms way. Best to get some local input from an extension agent or a knowledgeable person at Southern States.
Diatomaceous earth is a good idea too. I never used it but it would have been a good idea.  I think it would take care of next year's problem too.
HM126
mike_belben
Late to the party but i knew it was gonna be vine borer when i saw that sad plant.  Theyve ate my yellow longnecks many times.
Ive got butternuts ready to snap the strings this year with no sign of harm from the flea beetles, june bugs or borers.  Maybe give butternut a try.
Praise The Lord
ESFted
I'm in Yorktown and have been growing squash and zucchini in raised beds for years.  I try to plant early in the spring so I get some produce before the vine borers attack.  I've never had any luck preventing the borers, but have had good luck running a straightened paper clip up and down the stem after I see the hole where the borer goes in ( you can tell by the frass coming out of the hole).  Also, if you cover the vine with dirt every few feet, it will root and keep growing and producing.
This year I tried injecting liquid BT (Bacillus thuringiensis) into my squash stems before the bugs arrived and have had really good luck with that technique.  No apparent harm to the plants so far.
S.U.N.Y. College of Environmental Science and Forestry '65
Stihl MS661CRM, Stihl MS460,  Stihl MSE 220, Solo 64S, Granberg Alaskan MK-IV CSM
Dreams of a Wm LT70 w/all the accessories
btulloh
BTW, the borers won't mess with butternut squash.
HM126
