Author Topic: Diesel or Soap Water  (Read 1328 times)
WDH and 1 Guest are viewing this topic.
Offline pezrock
« on: October 08, 2021, 01:03:13 AM »
I ran diesel in my blade lube drip today for the first time. Wow, I was shocked at the difference. Clean blade, less noise from blade guides and went through logs like a hot knife through butter. Maybe some of it was in my head but for now I'm sold. I also only drip 2 drops per second. Thoughts?
Offline SETexan
  • New guy here.
Re: Diesel or Soap Water
« Reply #1 on: October 08, 2021, 03:27:34 AM »
 What ratio to water did you run?
Waiting on HM130MAX!
L3940 Kubota
Offline ladylake
« Reply #2 on: October 08, 2021, 03:49:31 AM »
 I used to run water in the summer but have switched to diesel year around.  Steve
Timberking B20 15000 hours +  Case75xt grapple + forks+8" snow bucket + dirt bucket   770 Oliver   Lots(too many) of chainsaws, Like the Echo saws and the Stihl and Husky     W5  Case loader   1  trailers  Wright sharpener     Suffolk  setter Volvo MCT125c skid loader
Offline kelLOGg
« Reply #3 on: October 08, 2021, 05:44:06 AM »
I have always used diesel - just a few drops per second also. I give the sawdust to neighbors and use it myself on paths through the woods. I once gave it to a neighbor for use in his chicken coop but he said he couldn't use it because he could smell diesel in it. It surprised me he could detect it with all the pine, cedar and oak present. No one else has ever complained about it and I can't detect it either. He must have an incredible sense of smell.
Offline JoshNZ
« Reply #4 on: October 08, 2021, 06:22:46 AM »
I remember spraying a bit of diesel on the blade from a squirty bottle and being amazed... Built a dripper and have used diesel in it ever since.
Offline aigheadish
  • Tiiiiimmbeeerrr!
« Reply #5 on: October 08, 2021, 06:24:53 AM »
I'm a big know-nothing on this topic but I'm surprised the diesel doesn't leave too much oil on the wood...
New Holland LB75b, Husqvarna 455 Rancher, Husqvarna GTH52XLS, Hammerhead 250, Honda VTX1300 for now and probably for sale (let me know if you are interested!)
Offline customsawyer
    • The Custom Sawyer
« Reply #6 on: October 08, 2021, 06:57:23 AM »
I've used diesel for years. I think a couple of drips per second might be a bit to much. My mill has the lubemizer and I use it at the slowest setting for most sawing. Heart pine and Liveoak get a little more.
Two LT70s, Nyle L200 kiln, 4 head planer, 30" double surface planer, Lucus dedicated slaber, Slabmizer, and enough rolling stock and chainsaws to keep it all running.
www.thecustomsawyer.com
Offline thecfarm
« Reply #7 on: October 08, 2021, 07:02:08 AM »
I thought too much too. Don't take much to lube that blade with diesel.
I only saw for out buildings. No nice hard wood for furniture. I built a Women cave for the wife. If she could smell diesel, she would have told me.  ;)  ;D
Offline pezrock
« Reply #8 on: October 08, 2021, 08:38:15 AM »
Not quite sure. I just squeezed the bottle until a couple times.
Offline Nebraska
  • Lurked for quite a while, learning !
« Reply #9 on: October 08, 2021, 09:30:15 AM »
A drop per second is way plenty for diesel.(in the logs I saw... not a bunch of pine or other sappy stuff...)  I try to set mine a little a little slower.  I don't use any water.
Offline ajsawyer
« Reply #10 on: October 08, 2021, 11:11:50 AM »
Have any of you tried ATF?
Offline caveman
  • In the land of the blind the one eyed man is king
« Reply #11 on: October 08, 2021, 04:31:02 PM »
We use cotton picker spindle lube or diesel.  When cutting hickory, live oak, heart pine or anything else that the cotton picker spindle lube does not readily keep off of the blades, we switch the valve to the diesel lube tank.  If the blade starts to get a little pitch on it, we'll run the blade for a few extra seconds at the end of the cut or increase the diesel drip until the blade is clean throughout the cut.
As a benefit, the used blades are difficult to tell from new ones as they have no rust and are shiny.
I do not worry too much about shorter B57 life as they are relatively inexpensive compared to a ruined pair of live oak slabs or a longleaf pine beam caused by a gummy, diving, stretched out blade.
Caveman
Offline JoshNZ
« Reply #12 on: October 08, 2021, 04:53:02 PM »
I would say a drop per second even is a lot. Sometimes I forget to turn it on and after some pitch build up it only takes a few drops to clean it. Back it off until you see build up then open it slightly you might even find you're down at one per 10 seconds for some woods.
It all somehow just dissapears in the sawdust. With black walnut I've been pressure washing everything before I stack it for drying so that there's no bits masking the oxidation/colour change. Anyway sometimes the tap is running a bit fast and Im too lazy to bother tweaking it, I've noticed when washing it the rainbow oil colours across the board, so there definitely is diesel residue but it doesn't seem to bother anything. Can't smell it once dry.
Offline SawyerTed
  • Summey Lumber Services, LLC
« Reply #13 on: October 08, 2021, 08:58:07 PM »
I use Dawn and water.  Lots of Dawn, 1/2 to 3/4 a cup per lube jug full of water.
I have a 1 gallon sprayer that hangs on the control console, it has diesel in it.  A shot with sprayer before entering the cut cleans up the blade.  Prior to changing blades I give the blade a shot of diesel to clean it up and oil it.
So for me itís both not either or.
Woodmizer LT35HD25, WM BMS 250, WM BMT 250, Kubota MX5100, IH McCormick Farmall 140, Husqvarna 372XP, Husqvarna 455 Rancher, Ram 3500 6.7 Cummins
Offline Crossroads
  • letís make some sawdust
    • Kevin Bales faith family farm and portable sawmill
« Reply #14 on: October 09, 2021, 12:47:36 AM »
When I First moved to Idaho 3 years ago, I went to a mobile job in Lewiston and when I got there my lube system was frozen solid. After that I switched to diesel and have never looked back. Although it doesnít seem to work very well on the western larch sap.
2017 LT40 wide, Kubota l185dt, 2-036 stihl, 2001 Dodge 3500 5.9 Cummins, l8000 Ford dump truck, hr16 Terex excavator, Farmi logging winch, Valley je 2x24 edger, Gehl ctl65 skid steer
Offline Mainecoast
« Reply #15 on: October 11, 2021, 08:06:09 PM »
Iíve been using diesel with a bit of bar oil in it. Works well but the smell is awful. And I hate the kids playing in the sawdust. So I switched to water and soap. I did add the squirt bottle with diesel to clean the blade like others said..also at the end of the day I turn the water off and soap the blade with diesel and manually spin the blades to coat all the parts. Think about it. Weíre essentially just pouring diesel out on the ground. Then it goes into our wells and poisons us. I can smell the fuel in the sawdust.
Maybe Iím to green for most but...I grew up on the fish river in northern maine. After I left and returned to where I grew up my neighbor with a trucking business bought an old potato barn to use as a garage. The ground all around his shop stinks of grease and fuel. In the summer itís all you can smell. All that crap running right down into the river now. Luckily heís old and will be done soon. Then Iíll clean it up.
    • The Custom Sawyer
« Reply #16 on: October 12, 2021, 05:58:25 AM »
I think if you can smell it like that than you are using way to much. I've been using it for years and can't smell it around my mill. A 5 gallon jug will last 30K to 40K bf.  Then again maybe I can't smell.
Offline 1countryboy
« Reply #17 on: October 12, 2021, 06:33:25 AM »
Dawn and pinesol, if needed.  Sawing 30 inch White pine logs down 2 yrs.  If i use any.   Logs have dried out and no sap or sticky.
On or off road Diesel.  There is a huge difference?  Esp. the off road dye and smell.
Ohio Certified Tree Farm, Ohio (almost there, Centennial Farms), Ashland County Soil Conservation Award., USDA/ASCS/FSA forest management(TSI) 1963 to present,
Offline thecfarm
« Reply #18 on: October 12, 2021, 09:22:53 AM »
I only saw a little. But no strong smell around my mill.
Don't take much to lube that blade.
Offline Southside
    • White Oak Meadows
« Reply #19 on: October 12, 2021, 12:48:54 PM »
If there is a concoction I have tried it. For Maple, Walnut, etc I will use soapy water, but for pine it's diesel. Lube mizer on the lowest setting and you don't notice it at all. Like Custom Sawyer said, the tank lasts a long time.
Our off road diesel is ULSD so there is no smell or chemical difference between it and on road aside from the dye.
White Oak Meadows
Water in Diesel
Started by Corley5 on Forestry and Logging
Last post April 16, 2015, 11:27:48 PM
by barbender
How much water is OK in diesel?
Started by shinnlinger on General Board
Last post April 07, 2010, 07:16:08 AM
by james
water temp for diesel
Started by spencerhenry on Forestry and Logging
Last post March 21, 2008, 05:50:02 PM
by Polly
Diesel made from water! Yes, really!!
Started by fishpharmer on Alternative methods and solutions
Last post December 14, 2015, 06:59:49 AM
by Randy88
