Author Topic: Stihl MS 261 Performance Tuning Kit.  (Read 15471 times)
Offline ladylake
Re: Stihl MS 261 Performance Tuning Kit.
« Reply #20 on: November 18, 2016, 04:10:30 PM »
 The 20% faster cutting far outweigh any disadvantage's, I really like that picco chain..  Steve
Timberking B20 15000 hours +  Case75xt grapple + forks+8" snow bucket + dirt bucket   770 Oliver   Lots(too many) of chainsaws, Like the Echo saws and the Stihl and Husky     W5  Case loader   1  trailers  Wright sharpener     Suffolk  setter Volvo MCT125c skid loader
Offline HolmenTree
« Reply #21 on: November 18, 2016, 04:18:05 PM »
I agree Steve.
Plus SawTroll who is very critical about weight should know the chain is lighter too . :D
Here's the back of the package . Says on the bottom Made in Germany.
Offline ehp
  • logger/chainsaw hack
« Reply #22 on: November 18, 2016, 05:51:30 PM »
How much power will it stand before it breaks , I'm running 3/8's on this ported 261 and it cuts just about the same in hardwood as the stock 372's /461's
Offline HolmenTree
« Reply #23 on: November 19, 2016, 12:09:24 PM »
I've milled a few thousand feet of 2"6" lumber on my Alaskan with this little Picco on my 066 Mag.
Still haven't broke the loop yet.
Offline aSmith
« Reply #24 on: August 18, 2017, 04:33:34 PM »
Just picked up a 261 and the dealer had no idea about running Picco on it. Sounds like I'm gonna have to cross the bridge and try to find a tuning kit in Windsor. Any idea on the model number?
Holmen, what size bar are you picco-milling with? And how long would you go? Wondering if I should make that adjustment too. Thanks,
Adam
Offline HolmenTree
« Reply #25 on: August 18, 2017, 07:17:31 PM »
aSmith, welcome to FF, I believe these kits are no longer available on that special price (been a few years ago) but the Logosol 16" bar is still in inventory.
I ran the 16" Logosol Stihl sells plus a 7 TPicco spur sprocket drum Stihl also sells for the 066/660.
I was milling cants with to my 090 on a 36" Alaskan.
Then when it was time to mill lumber off the cants I mounted the 066 with 16" Picco bar/chain in the Alaskan mill.
When I had a hired man he would run the 066/16" on a homemade mill set at 1 1/2" while I kept milling cants with the 090. We cut over a thousand bf one day milling 2"6"16' spruce.
I tried the Picco chain on the 36" 090 mill but in time the chain kinked up too bad with all the chain stretching.
Offline ButchC
« Reply #26 on: August 21, 2017, 08:39:52 AM »
The 63PS is indeed great chain however has been NLA at Stihl for at least a couple years. The green tag version is much slower in my experience about on par with N1C Carton and 91 Oregon. Luckily  I have a lifetime supply  of 63PS since I dont use that much of it :)  Baileys does  list it on the web site in both loops and reels.
Peterson JP swing mill
Morbark chipper
Shop built firewood processor
Case W11B
Offline HolmenTree
« Reply #27 on: August 21, 2017, 10:05:46 AM »
Stihl 63PS chisel is still available from dealers here in Canada last time I looked.
Offline snonut12
« Reply #28 on: October 10, 2021, 01:55:29 PM »
Been considering to switch over to 3/8 low profile (3/8 picco) on my 261C-M to pair up with my 241C-M which is a fantastic limbing saw. I see this tuning kit (as mentioned by the OP) is for 16 bar and chain. I already am running 16 on my 241 for better reach when limbing. I currently am running 18 .325 on my 261 and would like to keep the length the same. Looking though the bar and chain catalog I found 3/8 picco 18 bar under the model 250, part number 3005 000 4817
Anyway, can I run this 18 picco bar on my 261 and if so, what is the sprocket part number? And how many links 3/8 picco chains would it need for a proper fit? The catalog says the 16 bar on 261 requires 60 links.
Offline Tacotodd
  • To learn and help
« Reply #29 on: October 10, 2021, 03:31:08 PM »
Its not going to fit. That saw takes a 3003 mount. Keep on going. If you wanted Oregon part numbers I could help, but Stihl is more proprietary than I can look up.
Trying harder everyday.
Offline lxskllr
  • dummy with saw
« Reply #30 on: October 10, 2021, 03:48:58 PM »
Not apples-apples, but I had interest in converting my 026 to using picco chain; ideally with a 20" bar. It looked like it was gonna be more trouble than it was worth to me, using aftermarket parts, and requiring modification.
Offline SkeeterKev
« Reply #31 on: October 15, 2021, 09:03:39 PM »
You should be able to use the newer Stihl 23RSPro chain on your 261 (you need a 0.050 / 325 bar).  I have been using it over a year now on a Husky 346 and it has never run better.  I also use a Stihl 241 that runs 63PS with a 7 tooth rim sprocket.  You could fit your 261 up to run 63PS but I think 23RSPro is a better option.  You can run 7 or 8 tooth rims depending on what you are cutting.
Stihl Tuning Kit info..
Started by realzed on Chainsaws
Last post June 22, 2018, 12:17:36 PM
by Dogleg
Stihl 660 performance rebuild
Started by JD Johnson on Chainsaws
Last post November 02, 2013, 08:58:40 PM
by angelo c
Stihl MS044 Carb Tuning
Started by Montanaboi on Chainsaws
Last post November 04, 2019, 02:33:52 PM
by Andyshine77
Tuning a stihl MS211 by ear and tachometer
Started by MatthewG on Chainsaws
Last post February 25, 2014, 09:56:03 AM
by JohnG28
