Stihl 044 won't run
Started by sawman, November 04, 2004, 03:15:37 PM
sawman
 I just recently replaced the tank assy on this saw. It will run if I keep it choked, when choke is turned off the saw dies like it is running out of gas. Any input is greatly appreciated.
                                                     Thanks,
                                                       Larry
'14 LT40 Hydraulic 26 HP koehler ,massey ferguson 2200 forklift, Case IH D40
Wallenstein FX85
Kevin
Larry;
Was it working properly before you changed the tank?
I'm thinking there's a fuel restriction somewhere.
sawman
 yes, it was running fine beforehand, think i may get a chance to look at it more this weekend. I'll check the fuel line and filter.
It was a used assembly and i didn't even think about checking these before i put it all together. Thanks for the input.
Wallenstein FX85
sawguy21
Is the tank vented? Try a different cap
dozerdan
 Hi
 By any chance, did you forget to hook up the impulse line?  I have been there, done that. LOL
Later
Dan
Danny Henry
Central Pa.
Home of the Original Power Ported Saws
570 658 6232
dozerdan@sunlink.net or
dozerdan@nmax.net
