Thermally modified wood
Started by flatrock58, June 30, 2020, 09:59:00 PM
flatrock58
Does anyone know of a company in the Georgia area that will thermally modify your wood?  I know there are plenty that will sell you thermally modified wood but have not found one that takes your wood and treats it.
2001 LT40 Super Kubota 42
6' extension
resaw attachment
CBN Sharpener
Cooks Dual Tooth Setter
Solar Kiln
nativewolf
Liking Walnut
I had to google that one. Got it. :) Interesting. Costly? But safer.
flatrock58
Thermally modified lumber is wood that has been through a natural, non-toxic process that "cooks" the wood, changing the make-up of the wood. Wood is heated in 400+ degree heat in an oxygen-free environment. Thermal modification uses heat to remove organic compounds from the wood cells, so it will not absorb water, expand, contract, or provide nourishment for insects or fungi.
6' extension
resaw attachment
CBN Sharpener
Solar Kiln
flatrock58
Got a sample of thermally modified poplar.  It is dark all the way through the wood.  I could see this as siding.
6' extension
resaw attachment
CBN Sharpener
Solar Kiln
Southside
Funny - I think I have actually made some of that without realizing it.  I have a bunch of stickers that were Poplar and have been through the kiln umpteen times, they are dark as walnut.
White Oak Meadows
mike_belben
Oxygen free as in they draw a vacuum or displace oxygen with some sort of gas or what?
Praise The Lord
flatrock58
I believe they use steam to keep combustion down.
6' extension
resaw attachment
CBN Sharpener
Solar Kiln
flatrock58
Found a place near Macon Georgia that will treat your wood for .80 cents/bf.  Minimum of 4000 bf.  That is about half the price of yellow wood treated lumber.  Might need to get some wood cut and dried and try it out.
6' extension
resaw attachment
CBN Sharpener
Solar Kiln
