New forklift (to me)
Started by Brad_bb, April 21, 2021, 12:43:51 AM
Brad_bb
 I just picked this machine up.  It is a "John's forklift" conversion like my other one.  My other one was converted from a Farmall BN, which is probably what 97% of their conversions probably were.  The previous owner and I believe this was likely an early conversion as it is missing some of the refinements of later conversions.  I plan to change the shifter design to the later one to make it easier to use and get on and off.  I will fabricate a new steering column bracket with dash and starting controls atop the column like later ones. i'll add a floor plate,move the battery and hyd tank back(interferes with your right leg position now).  I'll update the hyd control levers to the later type to function better.  it has 3ft forks now and I will change to 4ft.  i'll convert to pointless ignition, and probably add more counter weight.  typically they have 2500 lb lift capacity which does 97% of logs at the mill.
Bruno of NH
Nice looks in good condition
I always enjoy those conversion kits.
Even if not interested in buying, I will stop and look at one.
moodnacreek
 My first forklift was like that and I miss it sometimes. They are very handy and seldom get stuck and easy to put chains on. Looking at the distributor I wonder why you would do away with the points, I mean they are right there and they will never really let you down.
hedgerow
Nice find. Back in the day there were several around this area. There were quite a few tractors reversed around here with tractor front end loaders put on the rear to make a lighter duty type wheel loader. Buddy bought a reversed 880 Oliver last year with a loader on it. Its made him a nice yard tractor for the farm.
mike_belben
Ive got a miniature version sitting in mass half way finished, from a Case 222 hidrive with a chopped off little giant warehouse fork on it.  Made for driving up ramps into a container and various super tiny indoor garage chores that an old man [me, eventually] needs help with.
Praise The Lord
Brad_bb
It was not a kit.  John's was in business from the 60's til the early 80's.  They were located just outside Grand Rapids, Mi and served the orchard and veg farmers that used boxes for product.   I think liability and insurance made them quit.  They built frames under the farmalls, built all the controls and masts. They used a forklift axle on the rear of many and had their own counterweights cast.  I'll also fab and add an ROPS to this one like most others had.
sawguy21
That setup was popular in the orchards in our area, small tractors were plentiful and cheap. Many were home built, some were better than others.
Resonator
The way the tractor is set up reminds me of a project I had many years back. I was given an old International Cub Cadet lawn tractor to restore that didn't run. I bought a new Honda engine to replace the Kohler and bolted it in. When I hooked up the belt and took it for a test drive, I found out I had 1 forward gear, and 3 reverse gears. And boy that 3rd gear reverse was handful to drive in a straight line!
That was a interesting build they did than!!
chevytaHOE5674
A styled WC Allis. There was an outfit in Minnesota that did conversions on WC, WD, and WD45 tractors also. They worked well because it was easy to flip the ring gear over in the casting and all the original trans gears directions were flip flopped.
sawguy21
A friends dad bought a VW van that had four reverse gears, it would do 50 backwards. The po had rebuilt the transmission by the manual which omitted the fact the ring gear had to be flipped for use in transporters because of the portal axles. :D
Corley5
There's a forklift just like that for sale at a greenhouse/nursery in Petoskey.  Saw it today :)
mike_belben
Mine indoor mini fork mocked up
Praise The Lord
Bruno of NH
Corley5
  I'd like a forklift to put my sap head tank on so I can raise and lower it for cleaning.  I'm thinking an electric one with a small foot print that needs batteries and putting an AC motor on it.
mike_belben
The older electric forks are typically 24 or 36v DC.. Maybe 48v by now.  The ones ive stripped ran a dc motor into a hydraulic pump but i dont recall the RPM and the parts ive got are in mass or id check for ya.
Praise The Lord
Tacotodd
@mike_belben  you're one crafty dude! No wonder that S&W wanted you so bad.
Trying harder everyday.
Walnut Beast
Looks pretty handy Mike how much weight do you think you can move on a pallet?
mike_belben
It hasnt been finished yet and is up in mass, so i dont know.  I'll be happy if it shuffles axles and transfer cases around.
Praise The Lord
mike_belben
Its sitting right next to my little mud truck that i really wish was here right now.  The bed is for cement pours.
This was the first dirt machine i built and at the time was all i had.  You can see the hydraulic 3 point lift yoke on back that i dont even need anymore.
Praise The Lord
Corley5
Picked this up at an auction today.  Needs batteries but is supposed to work.
