Fixed DanG Weed Whip!!! I think....
Started by CHARLIE, August 12, 2005, 04:09:59 PM
CHARLIE
Tom was always the mechanical one in the family. I can do light stuff but just ain't too good making things run good when they don't want to.
My Homlite (don't laugh!) has been a good runner for about 5 years but now is giving me some problems running and I'm not sure where to look.  Any suggestions?
It will only run with the choke 1/2 on.  To me that means it's running lean but I don't know why. My chainsaw did that once and I found the fuel line was cracked inside the fuel tank. But on this weed whip, I don't see any air in the fuel.  Also, I have to barely touch the throttle trigger to keep it running. If I give it more gas (squeeze the trigger) it dies.  Sometimes it seems to just run out of fuel and quit. >:(   Any ideas are welcome.
I put in a brand new plug and the gas is fresh.  The air filter (sponge) is pretty DanG clean and the throat of the carb is clean.  It'll fire right up but will either quit real fast or will run half fast for awhile. It sure is hard whacking weeds with it right now.
Charlie
That's the way I run, half fast (for awhile).
Would the gas cap be cracked?  I tightened mine too tight and over time it cracked. Don't recall how it behaved but seemed similar to what you describe.
shopteacher
Try taking the muffler off and cleaning any carbon out of it and the exhaust port coming from the cylinder.  I've had that happen a couple times with those small 2 cycle engines and that's what it turned out to be the cause. It's worth a try anyway.
fstedy
Could be a small piece of dirt in the needle seat. Try backing the needle out                ( remember the turns so you can get it back in the same position ) several turns and pull the starter thru several times then reset the needle. Had an identical experience on one of them weed thingys me self.
Timberking B-20   Retired and enjoying every minute of it.
Former occupations Electrical Lineman, Airline Pilot, Owner operator of Machine Shop, Slot Machine Technician and Sawmill Operator.
I know its a long story!!!
Fla._Deadheader
If it has that little "Push Bubble" Primer thingy on the side of the carb, it may have a small crack in it. They won't leak, just won't run very well.  ??? ???
I figure his extension cord is too short.  ;D
MULE_MAN
 :D  :D   :D  :D  Only Tom could come up with that one  :D  :D   :D  :D
Wood-Mizer LT40HDG25 with Simple Setworks, debatker, 580 CASE backhoe
ScottAR
Might be the fuel filter...  They're usually inside the tank. Take a piece of wire, put a little hook on the end and fish it out the gas filler hole.
Scott
"There is much that I need to do, even more that I want to do, and even less that I can do."
[Magicman]
Had that on a couple Ryobi's, tried everything and the only thing that I came up with was I couldn't get gas from the tank due to the filter being clogged. Tried everything to clean it, but no go. Can't replace it because it's built into the tank, glued in place. ::)
Gave up and bought a MTD 4cycle. Fried it during the first tank of gas.  >:(
Took it back to the box store and got a new one. So far no problems and I LOVE the 4 cycle!
Quiet and a lot more torque then the 2cycle.
Quartlow
I ahd a homelit comercial unit for a while ( someone liked it better than me  >:( )
I had the same problem when it was new turns out it was sucking air between the carb and the jug. check the carb and related bolts and make sure all is tight. If its getting air it will result in a lean run condition. another thing that could cause it is crank seals.
A good test to find a leak is find your self a smoker, remove the air cleaner and muffler. Rotate the piston to bottom dead center. open the choke, and the throttle wide open. Using a small hose and somthing to fit tight into the carb opening blow smoke into the engine. If you have an air leak you will see smoke where its getting in the engine
A cone shaped rubber plug with a hose through the middle of it works great to get the smoke in to the engine
Breezewood 24 inch mill
Have a wooderful day!!
CHARLIE
Thanks for all the input of ideas.  I'll be printing them out.....except Tom's.....and working on it this next week.
And Tom......I had already tried the extension cord thing but I only had a 150 footer and it was 2 inches too short. I could  not quite reach the weed whip.  Then I pushed it around the block a couple of times but couldn't get the clutch to pop. ::)
Charlie
Ernie
Another good way to find an air leak between the carb and the engine is to get it running and squirt a bit of oil around the join and see if the problem goes away, if so, it's an air leak.
A very wise man once told me . Grand children are great, we should have had them first
CHARLIE
Great idea Ernie. That'll be easy to try.
Charlie
Charlie, if it comes down to getting a repair shop to fix it....Consider getting an MTB (Garden Works) wacker from Wallyworld for $90 bucks. I've had one for 3 years now. ;)
Bro. Noble
Charlie,
That thing acting up is probably just a sign from above that you need to lay it aside and go fishing--------maybe it will work better next week :D :D :D
Just spent three hours straight last night using mine.
For some reason it started doing the half choke thing! >:(
CHARLIE
Swampdonkey, this one has given me 5 or 6 years of good service.  Of course, 5 or 6 years up here is like 2 years in Florida, cause they have to use their's year around.  We only use ours 3 months a year. Anyway, I can't give up on it yet......;D
Noble, I've already tried that and was a lot of fun but the weedwhip didn't get any better while I was having fun. >:(
I've pretty much come to the conclusion that it's starving for fuel.  What is irritating is...I can't get to the fuel filter.  How in the cathair did they get that thing down in there? That is something that always irritates me when a manufacturer designs something that the customer can't get to.  Next, I'll pull the muffler and clean the ports.  The needle jet has a block on the screw so I can't back it out. I can only turn it 1/4 turn either way.  So I did that several times.
Charlie
Buzz-sawyer
Charlie
They feed the tube through the hole with extra length, then hook the filter and pull it back....get yourselfa length of tube.....I will be glad when you figure this out cause I have 5 of em in the same shape....kinda thinkin its inside the carb.
    HEAR THAT BLADE SING!
Engineer
Can't help you on your problem, but I've gone the cheap weedwacker route and it's not cheap in the long run.  Get a commercial grade Echo, or Stihl.  Don't buy it from the big box store, get it from a local servicing dealer.    I use my weedwacker (a new Echo 251E) about as much as my chain saws (2-3 hours a week) and I don't see myself ever getting a cheap POS chain saw, so why do the same with any small engine?  It will just cost more in the end.   I just got a brand new weedwacker this spring, after having a straight-shaft Echo for five years, I just couldn't get used to the CCW rotation of the head, so I went back to a curved shaft model.  My dealer had a waiting list for used commercial grade trimmers for the local landscape and lawn service companies, and I got myself into a brand new commercial-grade curved-shaft trimmer for $70 out the door and trade-in of my old one (list price was over $300).  Try that with a Ryobi or Homely-lite.
I have a few small engines that aren't top-of-the-line, and I always have problems with them.  A Homelite water pump, a Tecumseh-powered auger, and a Sears-Crapsman leaf blower.  They all use odd fuel mixtures and are unreliable.  Next tag sale we have, they're out the door.
I'll get off my soapbox now.   ;)
ohsoloco
I'm still using the same Homelite weed whacker that my dad bought at least twelve years ago, and it's probably older than that  ;)  I've had the same problem with it as Charlie describes.  I think I've been running it on half choke for eight years or more  ::) :D  It was running good for a while last year, and I think it was when I was using the saw gas in it (don't know if it really made a difference or not).  The only thing we've ever put in it was a spark plug or two, and a new head.  My biggest problem with it is the fact that it's a curved shaft.  I'm 6'2" so I have to hunch over to use it, and after a little while it kills my back  :(
shopteacher
I fixed that problem of all the different fuel-oil mixtures.  I use 89 oct and sthil oil mix  for my sthil saws in them all.  Haven't had one fail yet.  Homey hedge trimmer, McCowlick weed wacker, and 3 chain saws, one mix.  ;D
isawlogs
 I do the same ... 40/1 mix in them all ... I have not had one  blow up and if it did i would just get me another , and try again  :)
   Marcel
CHARLIE
Well, I pulled the muffler and the port and the spark arrester screen were in good shape and not carboned much at all. I cleaned them anyway.  I put it back together and fired it up with no difference.  So now I'm to the carberator.  I was told today that here in the northland, gas might sit in that carb over winter and varnish the insides. So he's betting the carb needs cleaning.  He's said to pull the carb and take it apart to clean it.....but.......
What would happen to the 2 cycle if I pulled the fuel line and squirted carb cleaner into the gas inlet tube, rehooked up the fuel line and started the engine to get the cleaner into the carb real good.  Maybe do this several times.  Would I burn up the 2 cycle engine?  I'd love to do this instead of taking the carb apart.  What do y'all think about it? ::)
Charlie
sawguy21
You will be taking the carb apart  for sure. Carb cleaner is murder on the diaphragms and the viton seat for the inlet needle.
It  is not complicated. Lay out the parts in order on a white cloth,(not the missus' dining room table cloth if ya know what's good for ya) being  careful not to drop anything on the floor,  and gently clean the little passages with carb cleaner and compressed air. The carb kit is not expensive so don't re-use the diaphragms and gaskets.
Charlie,
Put a couple of sponges on this fellows feet and give him a bucket of soapy water.
http://www.mekka.com/log/2005/01/researchers_cre.html
;D
CHARLIE
I reckon I'll be taking the carb off then.  I best see if I can buy a carb kit first though.
Tom, that's scary!  Living robots now?!!!  We're really gonna create a HAL someday.
Thanks to everyone for all the help.
Charlie
CHARLIE
I'm sorta like DanG in my thinking. If there is work to be done, I'll do a whole heap o' thinkin' to see if there is an easier way.  Maybe it's a Southern thing.  Maybe that's why there is so many things invented in the South. :)
Anyway, because of all the help and suggestions, I finally determined the problem was fuel related in that it wasn't getting enough fuel.  Either the fuel filter was clogged or the carb was gummed up.  I REALLY didn't want to take the carb off in the worst way.  So, I figured if I could get a carb cleaner to run through the carb, it would clean it out.
Well, Sea Foam Sales Co. in Hopkins, Minnesota puts out a product called Sea Foam Auto Marine Motor Tune-Up.  It can be used to clean injectors, clean carbs, carbon cleaner, fuel stabilizer, de-icer anti gel, Upper Cylinder Lube, Frees lifters-rings, Dries oil and fuel.  It says to use through carburetor or vacuum line. Use in oil crankcase. Use in all fuels, gas or diesel.  Use in all engines, 2 cycle, 4 cycle, Diesels.  Use in cars, trucks, boats, tractors and small engines.
I spotted the reference to the "2 cycle" and also the "small engines".  So.......I put 1 ounce of Sea Foam into the fuel tank full of 2 cycle oil and gas of my weed whip.  I shook it good to mix it up and then started the engine at 1/2 choke.  I then ran it at full throttle until the fuel tank was very close to empty.  The carb on my weedwhip has a little clear plastic primer pump on the top.  The thing I noticed the most was that when I first started the engine, the fuel wasn't moving through that primer much at all.  As the fuel tank got down to 1/2 empty, the fuel was really moving through the primer pump.  I figured the Sea Foam must've cleaned the fuel filter. When the tank was almost empty, I opened the choke all the way and moved the throttle trigger from idle to full bore, back and forth and back and forth.  Now the Weed whip will run at fully opened choke.
So, for those of you that have small engines that only run at 1/2 choke, I suggest you try running some Sea Foam though it by adding it to your fuel.  Anyway, it's worth a try. You don't have anything to lose but the price of a can of Sea Foam.
Sea Foam Sales Co.
P.O. Box 5178
Hopkins, Mn. 55343-1178
When added to crankcase (oil)
- Frees sticky lifters & rings     - Increases RPM's vacuum &
                                                  compression
- Cleans dirty parts                 - Cleans PCV valve systems
- Removes moisture
When added to gas or diesel fuel tank
- Cleans fuel injectors & carb jets   - De-ices & removes moisture
- Cleans carbon as you drive          - Diesel fuel conditioner & antigel
- Lubricates upper cylinders            - Stabilizes Fuel
When used thru injection or carburetor
- Cleans carbon build up        - Cleans intake valves & pistons
- Gives smoother idle             - Cleans catalytic converter odors
- Cures hesitations & pings    - Restores power & pickup
At high idle, with engine warm, slowly pour 1/2 pint thru carberator or throttle body throat. Flood or stall engine out.  ( If vehicle is port injected use Sea Foam thru PCV valve or a main manifold vacuum line)  Restart engine after 5 minutes. Be sure exhaust is well ventilated. Fumes will be extreme for a short time. Can be used in injector cleaning machines.
When used in small (2 or 4 cycle) engines
- Cleans carbon build up      - Restores power
- Cleans carburetor              - Smoothes rough idle
- Stabilizes fuel                    - Removes moisture
One pint treats 8 to 25 gal. of gas (avg 1 ounce per gallon) or 6 to 12 gallons of gas /oil mix (avg 2 ounces per gallon).  Does not replace oil. Use frequently.  For tune-up and storage of small engines, inject Sea Foam into carburetor or spark-plug holes. To fog engines for storage saturate internal parts thouroughly.
Y'all give it a try....I was happy with the results. 8)
Charlie
Well, Charlie, is Hopkins in Southern Mn.? :D
CHARLIE
Uhhhhhhhhh...no....I think it's a suburb of the Twin Cities........
Charlie
ScottAR
Sea foam is great stuff.  We sell it as fast as we get it at my job.  They make a pretty decent pentetrating spray too but it can't be as good as our sponser...  ;)
Scott
[Magicman]
