jred 670?
Started by chucker, May 13, 2009, 10:14:15 PM
chucker
 " OK " I AM CONFUZZELED!!!! what i have is a 670 with a strong blue spark ,geting gas ,new plug and the saw will not start? i checked the spark arrester to make sure it was not blocked . so the question is it possible for a 2 stroke to fire like a 4 stroke at 180 degs out with the spark being blue and wonty start?????????
respect nature ! and she will produce for you !!  jonsered 625 670  2159 2171/28"  efco 147 husky 390xp/28" .375... 455r/auto tune 18" .58 gauge
Kevin
Any chance it might be flooded?
sablatnic
Have you tried priming it? About a spoonfull of gas into the airfilter manifold? Or it might be flooded.
Enough compression?
chucker
compression is strong with a pull of the rope , but i have to check to see if the lower case is full of gas yet????when i pull the starter rope the exaust dose not spew gas out the muffler so i dont think the case will be flooded.....
GASoline71
Is the plug wet?
Gary
\"...if ya mess with the bull... ya gets the horn.\"
sablatnic
About the ignition timing might be off. It is possible, since the flywheel is keyed to the crankshaft with a steel key, but I have never seen it happen. The magneto in the flywheel should pass the ignition coil about 20 degrees before the piston is at top dead center. (TDC). I don't know exactly how much before, but if that is the reason, it is very far off, and should be easily seen.
Probably flooded or dry. If the plug is wet, you could try pinching the fuel line, to keep more fuel from entering the engine. But take care not to cut it.
Best of luck. It is time to sleep where I live.
Rocky_J
If it has compression and spark, then it's a fuel problem. The carb is the obvious first place to look, but before you do that I'd check the fuel filter/pickup, fuel line and impulse line. Gotta confirm that fuel is getting to the carb before we start tearing the carb apart.  ;)
chucker
ok .... new lines and filter, checked the impulse with no blockage? CARB HEY ????  plug was not wet but pulled the fuel line off and gas was squirting out the carb end of the line ... oh yea, gas in the throat of the carb and 1 pull it will start ...just wont stay running ????
chucker
 ok last try !! not wanting to tear into the carb and lose all those little pieces that i cat see anymore . took the saw to the shop to have carb rebuilt, to be back by wednesday ?? maybe making progress .... by the way i bought this saw new in 1988/89 with one other carb rebuild !!  " THANKS FOR HELPING TO WHITTLE THE POSSIBLES DOWN "
chucker
  it did not take till wednesday to fix the ole redone!! got a call last nite from the shop to come and get the buzzerd. good to know all it was was a pluged carb in one of the metering holes....  good to go for another couple years ??? i hope. total fix $81.55
GASoline71
When all it needed for maintaining the saw was a $5.00 dollar fuel filter at one time...
Gary
chucker
Quote from: GASoline71 on May 16, 2009, 08:45:33 PM
Gary
didnt say what it was for sure? it had to go through the tank filter,then the screen and then block the metering port?? so what ever it was it was worth the fix!!!!!
GASoline71
True... but put a different filter on it.  A lot of times a very old filter will disintegrate from the inside and that's where the crap that clogs the inlet screen comes in.
I had a Jonsereds 70E that I got for 20 bucks that had the same exact problem.  Guy couldn't get it to run, and was gonna hck it.  I gave a 20 and he let me have it.  Went home... checked out the rotted fuel filter, and knew that it was gonna have junk in the screen... yep... it  did.  Especially those older Jreds... the filter is a metal housing with a replaceble filter media... the media is what breaks apart after a long time...
So make sure you have a new modern style filter on that saw.  Or it will happen again.
Gary
chucker
been there done that with the original style filters ( stainless steel clip type)... now just use the full nylon type....
chucker
  cut 7 big w.oaks and ash trees today withqa fine running saw... biggest w. oak was 28" at knee high and the ash was 26" at knee high .otherwise the rest averaged 16".  ended up with 2 cords of firewood and 3 cords of saw logs for the mill .so not to bad for a saw that i thought was dead ?? now its time to retune the carb .................
GASoline71
Glad she's up and runnin'.  Why do you need to retune the carb?  Didn't you already tune it?
Gary
chucker
  lol readjust the settings for a final best after the carb is broke in again. you can always tweek a few more RRRRR,s out of them !!! and if she blows ? then time for a newer and bigger jred!!!!
GASoline71
Uh... you don't have to "break in" a carb mang...
You can set it and forget it if you do it right the first time.  Careful tryin' to "Maxx out the R's" you can lean seize the saw.
Gary
chucker
 " MORE POWER !! SCOTTY " ..........................
