3D printing and woodworking ( Watcha printing ? )
Started by 21incher, November 15, 2023, 07:22:54 PM
When I posted, your images were not showing up, then they did.
Crusarius
I really like the addition of the razor blade for the string cutter.
21incher
Quote from: Crusarius on February 04, 2024, 04:44:01 PMI really like the addition of the razor blade for the string cutter.
That's one of those 9mm snap off blades. It's an old rusty one to test if it works and Amazon just dropped off new ones. should be able to index it. A slit piece of rubber on the inside  to hold the cut end.  :wiggle:
21incher
Finally done working it out after 3 tries. Don't  ever believe dimensions found on a website 🙉
Got the spring loaded string holder 3d printed  and added a rubber  strip with a slit to keep the cut end in place. Fun little  project
Back to woodworking for a while  :wink3:.20240207_103949.jpg
21incher
A big 250 pack seed sorter.   A couple 3d prints and some fiberglass fence posts.
