Author Topic: building a house  (Read 659 times)
Offline Wayniac
building a house
« on: September 05, 2020, 07:43:58 AM »
what is better for framing lumber syp or poplar
wayniac
Offline Magicman
  • A "Traveling Man"
    • Knothole Sawmill
Re: building a house
« Reply #1 on: September 05, 2020, 08:22:36 AM »
SYP
Offline Don P
    • Calculator Index
« Reply #2 on: September 05, 2020, 09:13:37 AM »
Yup, I wish I had that option as I was framing with poplar this week.
Offline WV Sawmiller
    • Green's Sawmill Services
« Reply #3 on: September 05, 2020, 04:59:20 PM »
   I did a demo for our local USDA and Forestry dept last Feb and the Forester advised there the specs for poplar were real similar to pine so you won't be too bad off using either as I understand.
Online Dave Shepard
  • Geometrically proportional
    • My homepage
« Reply #4 on: September 05, 2020, 05:50:11 PM »
Engineering specs are one thing, behavior of the wood is another. SYP would likely be the winner in the manners department. Poplar has always done its own thing for me, and that usually includes some serious bowing.
Offline Don P
    • Calculator Index
« Reply #5 on: September 05, 2020, 07:38:19 PM »
I do poplar SDR, saw-dry-rip and it works fine that way. I framed a small 16x28' house last year mostly with poplar. Using that technique I'd put it up against box store framing any day of the week as far as straightness.
This span calculator is from the folks that write the tables in the codebook and has both species;
https://www.awc.org/codes-standards/calculators-software/spancalc
If you run the calc for 2x12 #2 poplar floor joists, max span is 16' which is what we did although most of the material was select struc., poplar is usually pretty easy to find nice wood.
Run the same thing in SYP and max span is 16'6" so as Howard said apples to apples not a huge difference.
Poplar does attract ppb's here so we treated both at the mill and then the finished frame with borate. The project this past week is a 120 year old timberframe with rot, ppb's and termite damage. I soaked the framing we were working on pretty heavily Thursday evening, put in foam insulation yesterday and will hopefully start residing that section next week. The windows we are making are poplar as is the siding that a local millwork shop reproduced.
That said if SYP grew here I would probably use it for framing.
Offline WDH
  • Forester
  • April 1998 - August 2008
    • hamsleyhardwood.com
« Reply #6 on: September 05, 2020, 08:25:10 PM »
Lots of stress in yellow poplar here, especially in smaller trees.  Saw-dry-rip would help resolve those problems for sure.
Offline Magicman
  • A "Traveling Man"
    • Knothole Sawmill
« Reply #7 on: September 05, 2020, 09:07:59 PM »
I refuse to saw framing lumber from 18 year old Plantation Pine with " growth rings.  If the customer insists, I saw one and show him why.
Yesterday's framing lumber was sawn from 75-80 year old trees with 1/8" growth rings.  Good stuff.
Offline Haleiwa
  • Clinton county, New York
« Reply #8 on: September 06, 2020, 07:28:05 AM »
Be aware that there are several species of trees that are locally referred to as "poplar", with very different characteristics.   Quaking Aspen  and Tulip Poplar are not at all the same (and neither would be a good choice for framing a house).  This is one case where using the scientific name can avoid confusion.
Socialism is people pretending to work while the government pretends to pay them.  Mike Huckabee
Offline Wayniac
« Reply #9 on: September 06, 2020, 07:32:10 AM »
thanks for the info i have plenty of both so i guess syp it is thanks again
wayniac
Offline samandothers
« Reply #10 on: September 06, 2020, 08:50:29 AM »
I have used tulip poplar on some framing material for a pole barn.  Man was it a challenge to saw due to stress.  Most all of it cut from a hill side.  Made some great rockers!
building a house for mom
Started by wheelinguy on General Board
Last post June 30, 2012, 09:42:31 AM
by bama20a
Building a new house
Started by Kingcha on General Board
Last post May 06, 2017, 06:31:05 AM
by scgargoyle
Building a house with a sawmill
Started by Jmiller160 on Sawmills and Milling
Last post May 05, 2022, 05:21:02 PM
by fluidpowerpro
Andy's building another house.
Started by Tom on Sawmills and Milling
Last post December 28, 2004, 02:48:55 PM
by SwampDonkey
