Author Topic: Timber frame questions  (Read 448 times)
Offline hopm
« on: September 03, 2021, 09:05:22 PM »
Requested to saw some beams for a builder in our area. He needs 12 beams 6”x8”x14’ with a 2” radia/arch cut on the bottom side. Material will be hemlock. This is my first attempt at such and I have a few questions and would appreciate your input.
Can these beams be installed green?
Will the 2” relief on the bottom cause tension to either build or release? And….what is the best way to remove material on the bottom side to give the arched appearance?
Offline JRWoodchuck
Re: Timber frame questions
« Reply #1 on: September 03, 2021, 10:59:33 PM »
Can’t help on the green install question but the best tool for cutting the relief would be a mafell hand held bandsaw. But they run $6,000ish.
Online Don P
    • Calculator Index
« Reply #2 on: September 04, 2021, 08:47:48 AM »
Or put the beams on roller skates and use a $1200 Jet or similar bandsaw.
Anybody remember their chord math, what is the radius? A swingset over the bandmill could swing the timber through a fixed head... if the swing point isn't a mile high.
Offline Old Greenhorn
    • Woodsman Forest Products
« Reply #3 on: September 04, 2021, 09:01:43 AM »
Check out the bandsaw that @tule peak timber shows in some of his photos, not sure the brand, but perhaps you could adapt a small hobby bandsaw to work upside down like that? Laying out the line will take some figuring, but it's do-able for sure.
Oscar 328 Band Mill, Husky 450, 372 (Clone), Mule 3010, and too many hand tools. :) Retired and trying to make a living to stay that way. NYLT Certified.
OK, maybe I am the woodcutter now.
I can work with wood, but I am NOT a Woodworker, yet.
Offline JRWoodchuck
« Reply #4 on: September 04, 2021, 11:02:00 AM »
Tule has a Mafell...
Offline scsmith42
    • Whispering Pines Farm
« Reply #5 on: September 04, 2021, 01:03:02 PM »
A Pratzi Beam cutter (short chainsaw bar that is attached to a worm drive circular saw) can be used to cut radiuses in beams.  It's not as fine of a kerf as a band saw, but works ok.
Tom's 3638D Baker band mill
Offline ljohnsaw
« Reply #6 on: September 04, 2021, 01:32:38 PM »
Draw out your arc and creative use of toe boards at each end... ;)
Offline Jim_Rogers
  • Board Moderator
  • Keep your chisels sharp.
    • jrsawmill.com
« Reply #7 on: September 04, 2021, 02:10:08 PM »
Tim, from Moon Hill Farm in Maine, did it on his band mill but slowly making the cut and raise and lower the band while traveling down the log.
show here:
Jim Rogers
Online Don P
    • Calculator Index
« Reply #8 on: September 04, 2021, 03:13:33 PM »
I had to do some circlehead windows in a log wall and used the prazi facing 90° to the cutline and swinging on a wooden pivot arm to do the final chainsaw cleanup, it smoothed it out a bit more.
The next one was a table large enough to push what I needed through a shop bandsaw. I've seen guys put skates on a shop bandsaw, support the beam and push the saw through the work.
Offline Jim_Rogers
  • Board Moderator
    • jrsawmill.com
« Reply #9 on: September 05, 2021, 10:03:52 AM »
If you cut away 2" from the 8" timber you'll have a 6x6 when done. If it were me doing it, I'd try and center the pith of the timber in the 6x6. That way what's left will be a boxed heart timber.
There is no way to know what the tension or stress is in that timber until you cut it. You'll have to "read" the timber while milling it to see if it moves as you cut it. And if it does try and release the stress/tension evenly.
Jim Rogers
Post and Beam/ Timber frame Cabin Questions- New to timber framing
Started by TimberHawg1 on Timber Framing/Log construction
Last post February 15, 2019, 02:01:04 AM
by D L Bahler
Timber frame barn plan questions
Started by cib on Timber Framing/Log construction
Last post October 27, 2019, 06:48:56 PM
by cib
20x32 timber frame workshop questions
Started by BoyZinthewoods on Timber Framing/Log construction
Last post April 09, 2016, 09:58:01 PM
by newoodguy78
Newbie questions on first timber frame build
Started by michilius on Timber Framing/Log construction
Last post October 01, 2021, 11:45:17 AM
by mattgancz
