Mud season!
Started by Woodhauler, December 07, 2015, 11:52:43 AM
Corley5
  #4 piston is broken, possibly from a piece of turbo impellor :-\  I found a 2000 E350 van with a 120,000 miles and a 7.3 for an organ donor.  The transplant is ongoing.  It was a pretty nice van  ;) ;D  Looks like a fairly straight forward swap.  A few accessories have to be switched from the truck engine to the van engine.  The van engine has a non waste gate turbo and is 215HP instead of the 250HP the truck engine produced with the waste gate intercooled turbo.  I'm not going to miss 35HP.  Otherwise from what I've read the engines are identical and they appear to be even the oil pans and exhaust hook up is identical.  I read the oil pans were different but not on this swap.  The van also had it's pan replaced not too long ago  8) 8) 8)
  Both engines are hanging and with a bit of luck we may get one back in the truck late today.
  It's supposed to cool off some next week but still be above normal temperatures.  There's rain in the forecast the next few days too.  Not even freezing at night.
lopet
I scrapped a working 7.3 last winter. Was originally a ambulance , then a plumbing/heating guy used it as a work truck.  Price was right, thought I will throw a flatbed on it.   It never happened .  :( ;D :D       Good luck with your swap.
snowstorm
Quote from: Corley5 on December 10, 2015, 08:00:08 AM
how did the engine swap go? did you pull the cab off or go out thru the front?
2StateTrigger
Quote from: Woodhauler on December 07, 2015, 11:52:43 AM
Got one load this morning, came home and stacked a cord of firewood and now I'm cleaning a dozen guns. >:(
Dont frown Woodhauler, cleaning guns is always fun.....
Molon Labe
Corley5
Got it running and back to hauling firewood 8)  It wasn't a bad project.  We went through the front rather than pull the cab.  If I had a gantry or bridge crane the cab probably would have come off.  We had to switch motor mounts, the driver's side exhaust manifold, the oil cooler tube that's on the driver's side below the exhaust manifold, the AC pump and alternator had to be switched from side to side and the truck power steering was part of that too.  There was a difference in the exhaust because of the exhaust manifolds but between the parts available we made it work.  It'll need a visit to a real exhaust shop some day ;) ;D  It runs good, starts good cold etc.  I'm happy with it 8) 8) 8) 8)
HiTech
We got a couple days in the teens coming up and one night below zero but then back to mild again. Won't be enough to freeze the ground with the snow we have but if a road is broke it might help with that, keep some of mud down for awhile. Want to use a gravel road to skid some timber on but can't unless it freezes solid. Any other year that road would be solid by now. Will probably have to use the skid trail in the woods but that will be a lot slower.
petefrom bearswamp
shut my job down last week, Woods OK but  mud flowing from the main skid trail onto the neighbors prop.
He aint friendly
Kubota 900 RTV
Polaris 570 Sportsman ATV
57 acres of woodland
Plankton
Had to call it yesterday for a few days. All the snow and freezing rain saturated the ground and the trail is worse then it ever was even in the rainy last couple weeks... I didn't even finish pulling out one turn yesterday, I unhichted it in the middle of the skid road didn't want to make any more ruts then I already had.
brianJ
Eight inches oflake effect snow before the mud froze up.   Mud is gonna stay around til spring.
Ken
We are getting some cold weather now but have enough of a snow blanket that if an area isn't tramped it will not freeze this winter.  I'm moving to a black spruce bog next week so will have to use every scrap of brush to build trails for the forwarder.
John Mc
Quote from: brianJ on January 01, 2016, 08:37:23 PM
Send some of that snow out my way, BrianJ.
I used to live near Syracuse, and my wife's family is from Pulaski. Where are you?
