Power drive down the track for band mill...
Started by Ljohnsaw, March 25, 2015, 12:30:19 AM
ladylake
  My TK B20 with well over 10000 hours uses  2  #40 chains with everything still original except the bronze bushings in the front idler sprockets.   Steve
terrifictimbersllc
In another year my 2001 LT40's feed chain will probably be out of adjustment (the threaded tail end rod pulled all the way to end of its threads).   Would I shorten the chain or should it be replaced?  Probably 3500 hr by then let's say.
Peter Drouin
Quote from: terrifictimbersllc on April 05, 2015, 06:52:49 AM
I cut some of mine off, 2 links, works well,
A&P saw Mill LLC.
License NH softwood grader.
It probably would be a good idea to remove the covers and check the power feed sprockets.  If they look good, then tighten it up and keep going.  The first thing that will probably happen will be a sprocket bearing failure.  When that happens, then replace the sprockets, bearings, and the chain which all need to be replaced at the same time anyway.
