How much do you use your shop bandsaw?
Started by hackberry jake, November 02, 2012, 09:59:18 PM
CHARLIE
Because I enjoy turning wood on my woodlathe and using wood gathered from woodpiles or fallen trees, I use my bandsaw a lot.  I have a large one that will slice a 12 inch thick chunk of wood.  Also, when I run across a particularly nice chunk of wood with a lot of personality, I can slice it up into small boards and plane them down smooth to build small objects like boxes or to use as accent to a project.  I couldn't be without one.
Charlie
Lud
Just talking and imagining here but I'd think it would be fun to build a vertical bandsaw that could take the same blades as my mill.
Couple of emergency wheels and tires, bunch of old implement steel for framing and a old lawnmower engine or electric as available. Set it up about knee high for resawing and the big stuff.
It's got the makings of a project! 8)
hackberry jake
I was just researching bandsaw stuff on here and found this. I started this thread almost two years ago! Well I finally have one and its coming along nicely.
as purchased
After a good sanding and painting.
Still gotta recrown the tires and maybe balance the wheels. I havent even powered it up yet.
Just think, in another 10 or 15 years, you will be there  ;D.
scleigh
Don't lie to us Danny, we'll never get there.
Every time I mention my next big project or purchase to my wife, she says, " will it ever be enough? And I say no!!!
hackberry jake
I told mine that im done buying tools... but I did mention my table saw is only 2hp...  ;D
mesquite buckeye
Hey hackberry- You got paint on the floor. My wife frowns on such like. :( ::)
Regarding the original question, I would use my bandsaw a lot more if I had one. :'( :'( :'( :snowball: :snowball: :snowball:
hackberry jake
Quote from: mesquite buckeye on August 28, 2014, 10:31:53 PM
Paint doesn't stick to dirt very well... I am hoping some paint thinner will wipe it away...
And it will just be a different color when the next tool gets painted...  8)
Kasba
I do mostly woodturn bowls to sell and I use my bandsaw more than my tablesaw. I also have to comment on many of the posts I have read that woodturners want wood for free. Please do not paint all wood turners with the same brush.
Timbery M285 25hp, Husqvarna 570 auto tune, Alaskan sawmill, Nova 1624 wood lathe, Dogo Argentino
21incher
Before I got my sawmill I used my band saw quite a bit for resawing and ripping warped pieces straight. The sawmill sure makes those jobs easier. But the band saw still sees a lot of use. :)
