Author Topic: Final Drying Thick Slabs 16/4  (Read 661 times)
Offline Jtd83
« on: October 08, 2018, 07:08:42 AM »
Hi everyone,
I have acquired a number of Maple slabs that are 12/4 to 16/4. Most 11-13" wide and 8 feet long. They have been air drying for over 10 years and have a moisture content of approx. 12 percent.
Based on my Reading, it seams it is very difficult to dry slabs this thick. All I really have access to is a homeade DH kiln that I made in my basement.
Any advice as to how I may be able to make this work?
Thanks!
Offline GeneWengert-WoodDoc
Re: Final Drying Thick Slabs 16/4
« Reply #1 on: October 08, 2018, 01:44:14 PM »
They do indeed dry slowly, very slowly at 80 F.  Heat speeds it up.  To get such thick pieces dry in a month or so, in the kiln, you need no less than 150 F and around 44% RH or 6.5% EMC.  Even then, the shell will be drier than the core unless you wait a bit longer.
Do you have an attic?  If so, storing (drying) a few pieces in the attic will work if they are not to heavy for the roof trusses.
To check the MC, use a moisture meter with insulated 2" pins, such as a Delmhorst with the 26ES electrode.  I prefer a digital meter.
Offline Jtd83
« Reply #2 on: October 08, 2018, 06:58:26 PM »
Thanks.
Why not a lower RH? Would that dry the surface even further and leave the core wet?
« Reply #3 on: October 08, 2018, 10:01:06 PM »
The lower the EMC, the harder it will be to machine the surface and get high quality.
Milling 3" to 5" thick oak slabs - mill to final size now, or after drying?
Started by stanmillnc on Sawmills and Milling
Last post June 19, 2019, 06:31:17 PM
by Don P
Drying thick oak slabs
Started by D6c on Drying and Processing
Last post November 21, 2020, 12:08:10 PM
by doc henderson
drying thick slabs
Started by copperhead10 on Drying and Processing
Last post December 06, 2014, 06:15:37 PM
by addysdaddy
Drying thick slabs and mantels-- new approach?
Started by Okrafarmer on Drying and Processing
Last post November 27, 2012, 08:53:47 AM
by Ironwood
