Author Topic: How thick should I cut cookies?  (Read 829 times)
Offline Merlin
  • Just trying to learn while Im here.
« on: July 11, 2021, 08:23:54 PM »
Hey everyone,
I picked up 12 rounds of red oak from a tree removal. The tree had some rot on one of the limbs about 15 up and ran down the tree a fair bit. The tree was over 4 in diameter, so the tree company cut them up into 25-30 chunks.
I will have to cut one side of the round so I can fit it on the mill so it will be about 32-35 across, but Im not sure how thick I should cut these? Or should I even bother to cut them into cookies. I do not need more firewood, so figured I could try and make some cool outdoor tables.
Any help is appreciated.
2018 LT15 Wide, 2012 Kubota M8540 w FEL, Norse 390 logging winch. IH 484 w FEL.  Stihl MS361, MS311, MS192. 40 acre family farm with NFLD ponies, a few beef cows, 2 Border Collies and a very understanding wife and 2 great kids.
"Imagination is more important than knowledge" - Albert Einstein
Offline Brad_bb
Re: How thick should I cut cookies?
« Reply #1 on: July 11, 2021, 09:20:52 PM »
I'm afraid the answer is - cut them to the thickness you will need plus a bit more to account for warpage and flattening.
Offline Southside
    • White Oak Meadows
« Reply #2 on: July 11, 2021, 09:37:22 PM »
Are your plans for immediate use or long term?  Red oak loves to check when in cookie form so be prepared for "character" cookies that will likely need some work later on.  For sure it can be a beautiful piece of wood, but likely someone will need to spend some time to make it so.
White Oak Meadows
Offline doc henderson
« Reply #3 on: July 11, 2021, 11:38:28 PM »
3 " plus
Offline scsmith42
    • Whispering Pines Farm
« Reply #4 on: July 12, 2021, 03:14:50 PM »
What Doc said.
Red oak cookies tend to split as they dry, so plan on some losses.
Tom's 3638D Baker band mill
« Reply #5 on: July 12, 2021, 08:52:22 PM »
i did some 30 inch x 1 inch oak, and they all split to the center and turned black.  stickered and air dried.  could have completer the split and jointed them and glues back.  the larger diameter the more stress and therefor the thicker the cookie.  trial and error.  some other threads with tricks, like denatured alcohol ect.
Offline Merlin
« Reply #6 on: July 12, 2021, 08:58:05 PM »
Thank you guys for the advice. I was thinking in the 3 range and will probably go about 3.5. The rounds have been cut for over two years but have been up on my hay wagon. The bark is slipping now and I hope to get a chance to cut a few of them in the next few days. Its just that the sun is shining so, need to make hay.
Ill get some pics of the before and after and post hopefully by the weekend.
Again, thanks for the advice. I wasnt sure if there was some type of ratio of width to thickness.
Offline burdman_22
« Reply #7 on: July 16, 2021, 11:20:07 PM »
A rule of thumb* is about an inch of thickness per foot of diameter.
*This rule of thumb was made up by myself and my brother, haha, but it always seems to be about right for our purposes.
Offline Brad_bb
« Reply #8 on: July 17, 2021, 10:04:57 PM »
I've cut some cookies, but never made anything with them yet.  Why couldn't you just cut a pie wedge cleanly where it checks, and use a sacrificial cookie to cut a corresponding pie wedge to glue in there?  Should nearly blend in/disappear, at least better than the check?
Offline DPatton
    • D & S Sawmill Services
« Reply #9 on: July 18, 2021, 08:34:54 AM »
Or fill the check with an epoxy. Ive seen some pretty nice looking rounds used as table tops that had the checks filled with colored epoxy.
TimberKing 1600, 30' gooseneck trailer, Chevy HD2500, Echo Chainsaw, 60" Logrite.
Work isn't so bad when you enjoy what your doing.
« Reply #10 on: July 18, 2021, 10:48:32 AM »
If you take a wedge or even half for that matter, from the very next cookie, should match well.  like book matched slabs.
Offline Larry
    • Copas Sawmill
« Reply #11 on: July 18, 2021, 11:01:53 AM »
Doc Gene suggested this method years ago and it does work well but its hard to get the pie wedge to fit perfect.
Doc henderson just suggest cutting two half's from adjacent cookies.  I think I like that idea even better.  That way I can run the half's across the jointer and get a perfect cut for the glue up.  I'm going to try that.
« Reply #12 on: July 18, 2021, 11:09:55 AM »
I did that on a bench I made for a fund raiser.
just did the edge but looks good.
Offline Merlin
« Reply #13 on: July 24, 2021, 09:13:34 PM »
Hey all,
Got a chance to get one on the mill. Got the bark off and cut it with the chainsaw to fit. Its about 33 wide and about 45 long.
There are a few soft spots but we will see how they turn out.
I ended up cutting them 3 thick.
I have them sitting on my log deck stickered for the time being out of the sun.
Anything specific I should do with these to dry that is different than drying lumber?
Out of the sun in a fairly windy area?
Thanks as always.
how thick is your firebox. Mine from Central Boiler is not as thick as you think
Started by Mocha2324 on Firewood and Wood Heating
Last post March 15, 2016, 11:38:06 AM
by Bert
Red Spruce....thick thick thick
Started by SwampDonkey on General Board
Last post May 15, 2004, 07:42:40 AM
by shopteacher
exclamation
Cookies!
Started by Patty on FOOD! FOOD! FOOD!
Last post November 17, 2007, 12:26:17 AM
by beenthere
Ash Cookies
Started by kelLOGg on General Woodworking
Last post February 06, 2021, 07:20:41 PM
by rastis
