Author Topic: Advise on cutting pine  (Read 708 times)
Offline Mhaaland
« on: September 02, 2021, 07:33:32 AM »
I am looking to make some board & batton, carsiding or whatever you want to call it.
I’m looking to make 3/4” thick by 6” wide planks.  My question is what dimensions should I cut it to accommodated for shrinkage, cutting tongue/groove and finish to thickness.
Offline GAB
Re: Advise on cutting pine
« Reply #1 on: September 02, 2021, 08:50:36 AM »
For a 3/4" finished thickness after properly drying and planning I saw 1" thick material.
If you are seeking a sawblade finish on the outside you might be able to saw a little thinner.
GAB
Offline scsmith42
    • Whispering Pines Farm
« Reply #2 on: September 02, 2021, 09:21:56 AM »
Most pine will shrink around 6% in thickness as it dries, so if you mill at 13/16” it should dry to around 3/4”.
If I’m milling to run the dry boards thru a moulder for a S4S T&G product, I’ll mill at 1-1/16” green. It will shrink to 1” dry and then I can plane 1/8” off per face for smoothing it up.
Sometimes I’ll make an 3/4” S3S T&G product with a rough sawn show face. In this instance I will mill at 15/16” green, it will shrink to around 7/8” dry and I will only plane the back face for a consistent dimension.
Tom's 3638D Baker band mill
Offline Mhaaland
« Reply #3 on: September 05, 2021, 07:10:58 PM »
Thanks guys!  Both reply’s are very helpful.
Pine cutting...
Started by sigidi on Sawmills and Milling
Last post November 03, 2004, 06:04:23 PM
by rebocardo
Cutting Pine
Started by Kingcha on Sawmills and Milling
Last post January 09, 2013, 10:14:42 PM
by Kingcha
I've been cutting pine.
Started by hackberry jake on Sawmills and Milling
Last post April 22, 2014, 04:54:22 PM
by terrifictimbersllc
cutting pine
Started by TexasTimbers on Ask The Forester
Last post January 03, 2006, 08:49:24 PM
by Pullinchips
