Author Topic: largest log so far on the LT 35HDG and new house pic  (Read 797 times)
Offline Durf700
« on: September 04, 2021, 04:23:16 PM »
this pine was 36" at the small end facing the mill.. and 41" at the far end!  not going this big any time again soon..  had to cut off some of the flare on about a third of the log to just take about an inch off around the log before I could start to get down to the board sizes I was going for.
just thought I would post this... been a while with the new home build we just finished up.  looking forward to building some more outbuildings now again with the mill!   the front steps are rough cut on the house, plan on installing rough cut on the walls in the garage and breezeway along with the entire rear deck.
Offline CCCLLC
  • It's not to big, load it!
    • Carolina Custom Cut
Re: largest log so far on the LT 35HDG and new house pic
« Reply #1 on: September 04, 2021, 04:33:21 PM »
Nicely done D700
Online Magicman
  • A "Traveling Man"
    • Knothole Sawmill
« Reply #2 on: September 04, 2021, 08:43:55 PM »
When I saw oversize logs I want the butt toward the sawmill so that I can easily verify whether the head will pass before I enter the log.  I hate to saw partway and then have to back out.
Offline Sixacresand
« Reply #3 on: September 04, 2021, 09:03:29 PM »
Sometimes, it is worth the time to remove the blade and see what the lowest elevation the head will pass.  I rather not deal with one that old.
"Sometimes you can make more hay with less equipment if you just use your head."  Tom, Forestry Forum
Offline Chuck White
  • Sawing Mobile since 2005
« Reply #4 on: September 05, 2021, 07:40:26 AM »
When I get one like that, I saw, turn, saw, turn, saw, turn until it becomes even!
It will become octagon or similarly shaped, then I can get a board from it!
~Chuck~
Retired USAF 1989, Retired School Bus Driver 2012, now semi-retired Mobile Sawyer, 2018 Silverado 4X4
1995 Wood-Mizer LT40HDG25 Kohler - Cooks Cat Claw Sharpener and single-tooth setter, 4-foot Logrite cant hook.
Offline YellowHammer
  • Take Steps to Save Steps
    • Hobby Hardwood Alabama
« Reply #5 on: September 05, 2021, 07:44:48 AM »
Nice sized log!
YellowHammerisms:
Take steps to save steps.
If it wont roll, its not a log; its still a piece of tree.  Sawmills cut logs, not pieces of trees.
Kiln drying wood: When the cookies are burned, theyre burned, and you cant fix them.  Dont burn the cookies.
Online Magicman
  • A "Traveling Man"
    • Knothole Sawmill
« Reply #6 on: September 05, 2021, 07:50:08 AM »
Like this.  :)
Online thecfarm
« Reply #7 on: September 05, 2021, 08:41:29 AM »
Nice looking home you have there!!!!
As I say, Enjoy your land!!!
Offline Durf700
« Reply #8 on: September 05, 2021, 12:30:56 PM »
HI Chuck!  that is what I did.  once I cut off about some of the flare with the chainsaw on the butt end that was over 40" then I made about 10 passes to get rid of the flare on the but end and was then good to go.  I think I got about 80- 8" 3/4" boards for my buddy at work out of this one log.
I would have spun the log around so the big end was at the other end like others mentioned, however my tractor is in the shop.. so this one as rolled over to the mill with 2 peavys.  I miss my tractor!  should have it back tuesday.
Offline Durf700
« Reply #9 on: September 05, 2021, 12:35:52 PM »
I had 3 more logs from this tree that I finished up last night.  I was very happy to not hit any metal in this project.  My buddy went and picked up this tree from someone selling it on facebook.  I was worried about hitting metal.
all said and done I ended up with 190 8" 3/4 boards plus a dozen 2x6's and a few 4x4's from it for him.  the cut off pile was actually quite small.  its amazing how less waste you have with 8' logs vs 12's and 16's.
Offline SawyerTed
  • Summey Lumber Services, LLC
« Reply #10 on: September 06, 2021, 03:59:28 PM »
Ive done the crazy large log thing a couple of times.
While the challenge is fun, it is tough no the sawmill and the sawyer.
Woodmizer LT35HD25, WM BMS 250, WM BMT 250, Kubota MX5100, IH McCormick Farmall 140, Husqvarna 372XP, Husqvarna 455 Rancher, Ram 3500 6.7 Cummins
Largest saw log ever?
Started by rmihalek on Sawmills and Milling
Last post September 01, 2004, 07:46:43 AM
by samdland
Worlds Largest axe
Started by SwampDonkey on General Board
Last post June 22, 2004, 08:03:54 PM
by Jeff
Once the third largest cottonwood in WI
Started by Wisconsin on General Board
Last post March 20, 2014, 03:07:46 PM
by shelbycharger400
smiley
Worlds largest CSM
Started by Rybot on Sawmills and Milling
Last post May 04, 2021, 10:31:26 AM
by Rybot
