Author Topic: How to mill a large log in the field?  (Read 1552 times)
Offline Brad_bb
Re: How to mill a large log in the field?
« Reply #20 on: September 11, 2021, 01:40:08 AM »
If they are anything but top grade logs, I'd abandon them.  Too much work to get to site, and drag the wood down and drag equipment up and down.  I hope you could use a 4 wheeler?
If they are top grade logs, AND you can use a 4 wheeler and a small log arch, then I'd quarter them with a chainsaw(I'd use my STihl 661), and pull the quarters out of the bush.  Then I'd reverse roll quarter saw them on a hydraulic band mill.  Getting the quarters down would still be a lot of work.  Consider how much it would cost to buy equivalent logs delivered to you versus the amount of work this will take.  You'll still have to load the quarters on a trailer and need equipment to do that.
Offline Tacotodd
  • To learn and help
« Reply #21 on: September 11, 2021, 05:13:02 AM »
Changing the degrees to 0 wont make it cut any faster, only give you a slightly better finished looking cut.  :P
Trying harder everyday.
moved
MOVED: How to mill a large log in the field?
Started by chet on Forestry and Logging
Last post September 08, 2021, 10:55:38 AM
by chet
Does anyone here operate a large portion of the mill as a shingle mill?
Started by just_sawing on Sawmills and Milling
Last post December 10, 2014, 06:10:48 PM
by just_sawing
I need someone that will mill a large log in VA near D.C. - - DONE
Started by DR_Buck on Wanted
Last post December 08, 2009, 03:14:05 AM
by johnmetz33
Photos of large fir on mill
Started by JD350Cmark on Sawmills and Milling
Last post December 17, 2008, 09:59:42 AM
by SwampDonkey
