Author Topic: drying slabs  (Read 927 times)
Offline xlogger
drying slabs
« on: April 05, 2015, 07:39:44 AM »
I getting into cutting more live edge slabs lately. As of now I've not started on a kiln and just air drying them. At what point can I take them off stickers and stand them up for people to see them. I know that they will not be dried enough but some go faster than they are dry. Mostly cedar, maple, oak, ash and cherry for now.
Offline Seaman
  • Still learning as hard as I can go.
    • Uniquewoodcuts.com
Re: drying slabs
« Reply #1 on: April 05, 2015, 08:19:27 PM »
XL,   EVERYTHING I have stood up before dry kiln , for a long period ( weeks) has cupped a little.  I do not have a lot of experience tho, some on here can add more I am sure.
FRank
Lucas dedicated slabber
Woodmizer LT40HD
John Deere 5310 W/ FEL
Semper Fi
Offline WDH
  • Forester
  • April 1998 - August 2008
    • hamsleyhardwood.com
Re: drying slabs
« Reply #2 on: April 06, 2015, 07:59:02 AM »
It would be best if they were below 30% moisture content.
Woodmizer LT40HDD35, John Deere 2155, Kubota M5-111, Nyle L53 Dehumidification Kiln, and a passion for all things with leafs, twigs, and bark.  hamsleyhardwood.com
Offline Ga_Boy
  • Been rode hard and hung up wet; more than once.
Re: drying slabs
« Reply #3 on: April 06, 2015, 02:43:09 PM »
General rule of thumb for air drying thick material is 1 year per inch of thickness.  Use as much weight as you can to keep it flat.
Reminder: moisture meters are not accurate above the 25-30% moisture content range.  This means you will have to have a sample for each species that you are drying and will need to weigh each sample and use the weight to calculate moisture content.  The formula for this process is in the USDA books.
10 Acers in the Blue Ridge Mountains
Online beenthere
Re: drying slabs
« Reply #4 on: April 06, 2015, 03:44:40 PM »
Forumla is (Wet weight - dry weight) / dry weight = MC % / 100
So the difference in weights divided by the dry weight times 100 equals the moisture content.
drying slabs
Started by Doug Wis on Drying and Processing
Last post July 14, 2014, 05:37:44 AM
by venice
Air Drying Red Oak slabs?
Started by John Mc on Drying and Processing
Last post November 24, 2017, 07:57:56 PM
by scsmith42
Drying Oak slabs
Started by JAG on Drying and Processing
Last post March 11, 2014, 07:55:30 PM
by JAG
Drying Burr Oak slabs
Started by D6c on Drying and Processing
Last post June 11, 2018, 02:42:22 PM
by GeneWengert-WoodDoc
