Author Topic: Releasing southern pine  (Read 906 times)
Offline bdubya
« on: January 21, 2018, 11:37:14 AM »
What is best? Brush cutter or chainsaw?There are patches approximately of about 0.1 acres if dense 1 to 2 inch caliper oak trees in the loblolly stand north fl. I want to cut the trees and treat the stumps. Probably with glyphosate. Thanks for your help.  Any suggestions?
Offline Claybraker
  • Mostly New!
Re: Releasing southern pine
« Reply #1 on: January 21, 2018, 02:08:38 PM »
Garlon 4  or generic equivalent, also gives broad spectrum on some of the other nasties we get around here. A foliar spray in a few months when you get full leaf extension, then hack and squirt or fill and drill with Tordon for the ones that are too tall to wet the foliage.
Offline bdubya
« Reply #2 on: January 22, 2018, 06:38:51 AM »
Thanks claybreaker. I believe this can be best treated as a hack and squirt. I want to address trees in 10 of thousands. Do you have experience with a brush cutter? Hopefully it will be more effective than a chainsaw.
Online WDH
  • Forester
  • April 1998 - August 2008
    • hamsleyhardwood.com
« Reply #3 on: January 22, 2018, 08:28:48 AM »
Look into a basal spray.  25% garlon 4 and 75% diesel fuel or crop oil.  Spray the base of the stems you want to eliminate.  The garlon 4 label has specific instructions on how to do it.  If you use a backpack sprayer, you can go pretty fast, much faster than a brush cutter or chainsaw then spray the cut stump and much faster than hack-n-squirt.  I believe that the stems have to be 6" in diameter or less, but that is also detailed in the instructions on the herbicide label.  Here is link to the label.  Look at the top of page 7 at the Low Volume Basal Bark Treatment.
https://assets.greenbook.net/16-33-15-25-08-2017-ld7IN006.pdf
Woodmizer LT40HDD35, John Deere 2155, Kubota M5-111, Nyle L53 Dehumidification Kiln, and a passion for all things with leafs, twigs, and bark.  hamsleyhardwood.com
Offline timberking
« Reply #4 on: January 22, 2018, 01:03:51 PM »
Burn baby burn
Offline bdubya
« Reply #5 on: January 22, 2018, 08:54:32 PM »
Thank you for the suggestion. I will research this. Avoiding the mechanical prep is pretty huge. I will get back on this.
southern yellow pine
Started by bandmiller2 on Sawmills and Milling
Last post February 09, 2008, 07:51:19 AM
by bandmiller2
Southern Yellow Pine ?
Started by woodhick on Ask The Forester
Last post September 22, 2017, 12:10:42 PM
by bucknwfl
Southern Pine Beetles (I think)
Started by Beavertooth on Drying and Processing
Last post August 27, 2015, 08:56:26 PM
by Magicman
Southern yellow pine
Started by BigZ La on Drying and Processing
Last post September 08, 2016, 09:28:26 PM
by GeneWengert-WoodDoc
