Just wondering what is the best make of spark plugs for chainsaws. I know with some of the new materials in the past 10 years they have improved upon them.
Has anyone had any luck with the newer spark plugs and do they add any advantage?
Sorry if this topic has been brought up before.
Thanks,
i use the bosch or ngk
so long as a saw run good I can't see a plug adding any advantage. Steve
I will buy Bosch if they don't carry Bosch, then I will go for NGK. I have bought Champion in the past but they seamed to not last as long as the Bosch plug.
Depends what country those Bosch plugs are made in. I ordered a box of 10 from Baileys a while back and found they are made in Brazil. Had a few duds already after limited use. Never had that problem with the Boschs I've run made in Germany.
Willard.
NGK by a long way, they seem to outlast anything else in the chainsaws, ATV, and mill
"CHAMPION" all the way, from start to finsh... it will get you there and get it done!!
I've always found all spark plugs to be pretty much equal, the only exception to that is Champion. I think every spark plug I have ever fouled was a champion, I'm not real fond of them. I usually use NGK, between a Husky 346, Jred 2165 and 2171 I have never fouled a single plug in any of those saws. I know my 2171 still has the original NGK plug in it, I think I have had that saw 4 years and I run my saws a little richer on pre-mix oil, too. My 2165 still had the original NGK in it when it threw a rod bearing, I might have changed the plug in the 346 when it melted down and got rebuilt ::) I don't even think about spark plugs anymore.
NGK'S for me I run them in everything........ The one in my wheeler has been there since I bought it new in 2005 as has the same battery.... I run 1-350....2-346XP'S...2-359'S.....1-372XP Ported & 1-3120XP & the plugs in those saws are 3 yrs & older.......Cars ,Trucks.Tractor,Skid steer, Excavator, Saw mill, Splitter & Wife..... 8) 8) 8)........Never had a fouled or bad plug yet.....But the Wife does act like a fouled plug when I drag mud in the house....... smiley_furious3 pull_smiley smiley_furious3..........Cheyenne
Quote from: HolmenTree on April 11, 2011, 10:54:25 AM
Willard.
Go figure, the Bosch plugs I got were made in India.
the "no good kind" or "botched" plugs make great fishing sinkers for catfish !! if you lose them your not out of anything, but gain a grin just knowing they wont be seen again.... 8) 8) ;D
Quote from: cheyenne on April 14, 2011, 08:39:55 PM
She sputters, acts erratically, and won't "ignite your fire"? Sounds familiar.
Quote from: sawyer04 on April 15, 2011, 12:11:31 AM
Willard.
Whats next, China? Yes I have a few India ones too.
For a matter of interest I still have a couple of brand new in the box Bosch WS6 plugs with " West Germany" on them.
Willard.
I got some older NOS Bosch that still has the brass colored screw on tips. The rest of the newer ones have silver tips.
any body try those e3 plugs yet
Quote from: tlandrum on April 11, 2011, 01:19:49 AM
Brazil made Bosch WSR 6F here, 1 plug a season bush whack'in 100 + acres Stihl FS550.
or NGK BPMR 7A
Quote from: simplicityguy92 on April 15, 2011, 11:38:14 PM
Yeah have tried a few , one within my lawnmower and another on snowmobile . Probably to soon to tell , I usually get a few yrs use with both examples. I know that they have sure reduced the price from when they first were introduced.
have always used bosch cause thats what my stihls have had in them from new and have never had a dud. Hardly ever replace them, only replace them when it looks like they are starting to get blowby or I think I should just for the sake of doing it.
NGK
I found no difference with the E3 vs. the standard NGK or Bosch. I'm also not a fan of Champions. We bought a new set to put in the woodsplitter (Wisconsin VG4D) and they worked very poorly...barely any change from the old ones they were replacing. We took them back to NAPA and exchanged them for a set from AC Delco and haven't had any troubles in roughly 1.5 years.
I use Champion in my push mower, but not my saws. I can use a Champion for years on that old mower because I don't put a lot of hours on it now that I have a lawn tractor.
I hear these stories of fouled plugs and kind of wonder .I've never experianced a fouled plug on a two cycle engine ever .Including old 50 year old outboard boat motors ran on 16 to 1 mix .
my stihl chainsaw will foul a plug, any brand if you look at it wrong. it needs some carb help. my honda tiller motor has a float stuck in it, it fouls the plug also.
we have a welder with a red seal engine on it, at times it will foul all the plugs at the same time, same with the 300 international tractor. the problems all come from the carbs dumping too much gas.
i also have a 175 hp evinrude that will foul a plug or two every now and then. but i think its because the coils drop out on it.
i use boshe in the saws and ngk in the boat and atv.
Oh I 've had a lot of worn out old tractor and car engine foul plugs .Not surprising after 150, 000 miles with the valve seals all but non existant or the rings completely shot .
Even with a good set of rings tractor and welder engines will foul them out if the low speed jet is set too rich ,given enough time if they idle long enough . It gets set so it will idle good at cold temps so you don't have to half choke it for 10 minutes at 2 below zero .
I have a herd of chainsaws. Some of these ive found, people have given to me, or they just showed up on my door step. Does anyone know of a chart that tells of spark plug/chainsaw application?
I had read about a brand of plug that was somewhat known for the electrode tips occasionally breaking off to create havoc inside especially chainsaw cylinders..
That would obviously make quite a mess before one of those bits finally got ejected or wedged into the squish area!
I thought it was the NGK brand - but I'm not sure now - it's been a while since I read about it.
Seems to me that was the reason why I went on a mission a few years back to try and find appropriate Bosch plugs for all of my small engine equipment..
I'll have to try a Google it for a follow up
I had an NGK plug do just that in my Jonsered 2171, pretty well destroyed the piston and cylinder.
Nagasakis in all my small engines except the outboard. I still prefer the champions for backtrolling there. Splitfires ran really good in the 15 Johnson, but the 25 Merc hates them.
I like NGK, never had a problem with them and they are readily available. I remember having problems with Champion, at least one out of every box would not fire or would quit in the first ten minutes but that was many years ago. I hope quality control has improved. Bosch is also very good but I seldom see them outside the bike and snowmobile shops.
I would never use a Champion plug on purpose. They used to let me down all the time in ATVs.
Champion was a great plug company, once upon a time....nothing better. Then sometime in the late 70's they started to have reliability issues. I starting running Autolite plugs in my rigs without even a burp.
Original German Bosch plugs in my saws would last so long that I just replaced them as a matter of course...not from failure.
Landscape changed and I went to NGK in my small engines. Thought I got a bad lot when they were slowly going bad in my J'reds 80. Turned out to be a coil issue, but in the interim, I found an original lot of NOS German Bosch plugs on eBay. So that's what I'm using in my saws.
I can't see how a spark plug could 'age' not being used.
Kevin
