Author Topic: What is a good light weight chainsaw? I have a good large powerful saw.  (Read 3588 times)
Offline Dave12
Re: What is a good light weight chainsaw? I have a good large powerful saw.
« Reply #20 on: January 08, 2021, 09:27:48 AM »
MS260 if you're on a budget.  Do a little muffler mod and remove the limiters from the carb and turn it up a bit and it'll rip.  MS261c if it's in the budget and you don't like messing around with carb adjustments.
Just a small time firewood cutter using a Stihl MS261c and MS462c
Offline TNMailman
« Reply #21 on: January 09, 2021, 07:56:39 PM »
These were very good suggestions and I read every one of them and researched every suggested saw if I was not already familiar with them. I really appreciate all of them as switch brands of saws is no easy task.
I have never owned a ECHO anything but after seeing all of the recommendations on here, I ended up buying a Echo CS 400.
I was going to buy a less CC in the ECHO to keep the weight lighter but at the last second I seen the weight on the CS400 was the same weight as the Husqvarna 435 that I have been using for the last two years. So I decided a 40 CC saw would be better if my 60 CC Husqvarna saw was ever broke or stuck in a bind. I cant say enough about the 60 CC Husky as it has cut acres of Sweet Gums, Sugar Maples etc. My son told me that when someone sees my land never mention that it was done by chainsaws because they will never believe it.
Today I used the CS 400 off and and on cutting limbs from logs then cutting the log with the 60 CC. The ECHO 400 cut really quick and a lot of power. The temp never got out of the 30s today and the saw stated effortlessly every time. It has two bolts to hold the chain tight which is a must, and I will never buy another saw that only has one bolt. Only time and use will tell how durable this saw will be but initial results I could not be happier. Very grateful for the suggestions. I would not have ever thought of ECHO had I not posted on here and asked. Also, right before dark I decided to push the saw a little and cut the top limbs of a gum with the ECHO, the limbs were about 8 inches in diameter and it went right through them quickly, never bogged.
Offline lxskllr
  • dummy with saw
« Reply #22 on: January 09, 2021, 08:26:10 PM »
The cs400 is a great saw. I've used mine a lot, and done a lot of brush slashing, which means I was swinging it around using 100% arm strength. It naturally gets tiring after awhile, but it really is a lightweight, and I've spent many hours with it in my hands.
You might want to consider a muffler mod and retune. I can't compare to stock cause I modded mine before I really used it, but everyone says it really wakes them up.
Online trapper
« Reply #23 on: February 10, 2021, 06:53:46 PM »
Bought the echo 3510 to replace my 310  A bit lighter with more power.  Had the dealer put a 14 in bar on it.  Today at  7 degree out my ms 261 wouldnt start,  my ms 241 took 10 pulls to start.  The 3510 took 2 pulls to start.  Was impressed with it cutting through 12 in dead ash.  So far not impressed with my 261cm.  very cold it is hard to start.  Hot weather hard to start.  Runs good when it runs.  Dealer says nothing wrong with it.
Offline DHansen
« Reply #24 on: February 10, 2021, 09:02:16 PM »
If your primary concern is weight, look at a 2511P. Less weight than a battery saw once you add the battery weight.  I have been happy with mine. As far as the long run, I have only 8 tanks and four weekends with mine.  Time will tell.  But on red oak I have been happy with it's performance.  For me I was looking small and light, and this little 25cc saw fit my needs.
Offline barbender
« Reply #25 on: February 10, 2021, 09:18:37 PM »
Trapper, on your 261cm have you done the reset/calibration like in the manual? I never have, because I've never had an issue with mine but it would be worth looking into. It's -15 out right now, my 261 is out in the cold shed and hasn't been started in a month. I bet 5-6 pulls and it would be ready to rock.
Online trapper
« Reply #26 on: February 22, 2021, 09:28:44 PM »
Barbender book didnt have reset procedure in it  looked it up on the forum in holman tree thread and ran it with my wife timing me.  Dosnt seem to help  At about 10 degree I tried to start it and wouldnt start.  Used my new little echo that started in 2 pulls.  Half hour        i tried again and it started  Has done that several times.  In hot weather  it often does the same thing.
Offline doc henderson
« Reply #27 on: February 23, 2021, 02:27:41 AM »
they have had trouble with the fuel module, and my dealer put a newer one in my 261 despite the test being ok.  now it runs all the time.  must have an intermittent problem, that of course does not happen at the dealer.
Online Al_Smith
« Reply #28 on: February 23, 2021, 10:11:31 AM »
I can't  recommend any more modern saws because quite frankly I don't own any .However for a light weight the 024-026 Stihl's do a nice job.I have an .024 myself .Not an oak slayer unless you have lot of time but a good limber ,lighter cuts as a firewooder etc .Light as a feather and have enough power plus parts are  available at your friendly neighborhood Stihl dealer .For that matter available at your not so friendly dealers also .
Online trapper
« Reply #29 on: February 24, 2021, 11:30:14 PM »
Doc I contacted stihl through their website with my problem.  will see what happens. I have bought saws, 0turn lawnmower weedeaters and a blower from this dealer but have not had satisfaction with this saw.
Offline Echo-man1
« Reply #30 on: August 27, 2021, 02:49:24 PM »
The little Echo CS-3510ES works really great here so far. Will see how easy it starts when it gets below freezing here in Norway in a month or two. I have a larger 50cc saw and only uses the small Echo for small trees and cutting off the branches etc. Bought it a cople of months ago and it came with a 14" bar and 0.050" Oregon chain (91PX053G). The 14" Echo bar is rather narrow, so I bought the Oregon 120SXEA041 12-inch bar which has a larger radius nose-wheel (9 teeth) and put on the Husqvarna X-cut S93G 45DL chain. It cuts great. The Echo runs better and better now after 7-8 tanks of fuel thru it, but I strongly suggest to let a professional chainsaw mechanic adjust the carburettor on it. Mine did not run great out-of-the box, it needed a bit of adjustment. The EU-model has no carb limiters caps on them, but in stead the adjustment needles (L and H) has a special cylindrical shape with a flat portion on one side (single-D). I did find the special tool for it online. So I did adjust it myself, but it was tricky to adjust. Ideally one should have a tachometer and adjust the H-needle for no more than 13.000 rpm I believe (the manual states max 13.300 rpm). It's better to have it run a tiny bit too rich than too lean, so it don't over-rew and get too hot and get damaged.
Here is a video I made with the small 12-inch Oregon bar and the Husqvarna X-cut chain:
Weight with full tank of oil and gas with Oregon 12" bar and chain is 10.4 Lbs. So it is easy to carry. My 50cc saw weights about 14.9 Lbs.
Offline HemlockKing
« Reply #31 on: August 27, 2021, 03:02:38 PM »
I would say a 261 is overkill for 1-3 branches but none the less not necessarily a wrong choice since its still fairly light and nimble. I would go with a ms250 for that. I think the ms250 is great up to 12-14 stuff, and light enough to justify carrying it around for 1 limbs
Building the land of my dreams.
« Reply #32 on: August 27, 2021, 05:05:04 PM »
I like the 261 with an 18 or 20 inch bar, as it is easier to reach a limb on the ground without bending over so much.   8)
I would like to try an echo saw sometime.
Offline HemlockKing
« Reply #33 on: August 27, 2021, 05:18:22 PM »
I would say if all you’re doing is limbing the 250 could run the 18 inch bar no problem, probably even fell with it fine. But yeah you’re right a 20 inch bar. I do have a 026 with 18 but I end up using the 250 with 16 for limbing more often than not. For bucking firewood on the ground though I do enjoy using the 500i, only had it a few months, only 20” on it now, ordered a 28 and 36 and still waiting. It is nice and light for what it is
« Reply #34 on: August 27, 2021, 05:28:33 PM »
If I am putting up firewood, or trimming for the mill, I might have a variety of cuts so I like the idea that I can do what is needed.  I also try to not get too many saws out.  I have never ran over one with the track loader...yet!   :o :) :D  I want to keep it that way.
Offline HemlockKing
« Reply #35 on: August 27, 2021, 05:33:43 PM »
The 462? And +1 on the not running stuff over lol
Online Al_Smith
« Reply #36 on: August 28, 2021, 06:46:54 AM »
Things do happen   unfortunately .I resurrected a once good running  Stihl BG -85 blower that lost the battle with a 7,000 pound brush chipper .The worst I ever did was backing into a 10" I beam column with a bull dozer .It took some rather creative repair work on the concrete pier to fix it . < long story ---
I found after using my chainsaw i needed a good AXE try finding a good one at a
Started by Happysawer on Chainsaws
Last post December 15, 2020, 03:57:23 AM
by SwampDonkey
Smooth light and powerful ...
Started by lledwod on Chainsaws
Last post June 16, 2021, 05:42:57 AM
by thecfarm
The MS 880 it is powerful chainsaw.
Started by alsayyed on Chainsaws
Last post August 25, 2010, 01:25:24 PM
by Cut4fun
Used chainsaw market, good? bad? about the same?
Started by deerslayer on Chainsaws
Last post January 15, 2016, 03:18:55 PM
by Jiles
