Author Topic: X Chain tips and tricks  (Read 547 times)
Offline Owtlaw
« on: September 05, 2021, 05:21:23 PM »
I have a half dozen of these and they cut like a light saber when sharp.  I have however noticed that they tend to go dull all of a sudden.  There does not seem to be anything gradual about it.  Other than using a 7/32 file and a 30 degree cross angle as directed on the box, are there any tips or trick to sharpening this chain that I should know about?
Offline Tacotodd
  • To learn and help
Re: X Chain tips and tricks
« Reply #1 on: September 05, 2021, 06:45:41 PM »
Ive never seen a problem with mine. The only thing that Ive noticed is that with most chain its recommended to keep your file 90deg to the bar. I keep mine 90 to the tooth, Ive always got AT LEAST as good of cutting as any stock chain & usually better. Maybe that information will help.
Trying harder everyday.
Offline lxskllr
  • dummy with saw
« Reply #2 on: September 05, 2021, 08:23:41 PM »
You might be putting too much hook in it. That'll give fast initial performance, but the corner will fold easier, and dull fast.
WM tips and tricks
Started by 4x4American on Sawmills and Milling
Last post April 29, 2015, 11:09:41 PM
by 4x4American
Tips, Tricks, and any other helpful Advice
Started by SFires on Chainsaws
Last post March 16, 2017, 02:14:09 PM
by Babylon519
Woodmizer BMS250 Tips and Tricks
Started by Unclefish on Sawmills and Milling
Last post July 02, 2020, 11:32:24 AM
by Unclefish
smiley
TIG welding aluminium. Looking for tips and tricks.
Started by Dangerous_Dan on General Board
Last post October 21, 2006, 06:21:42 PM
by DWM II
