Author Topic: Help! Trying to find a replacement bar tip  (Read 780 times)
Offline scsmith42
    • Whispering Pines Farm
« on: September 07, 2021, 01:31:34 PM »
My dedicated slabber uses a 7' long .404 GB bar. Unfortunately GB stopped making these, and I need to find some replacement bar tips for it.
It uses what is called the "M" style tip, which I "think" may have been used by some older Husqvarna saws.
I was able to source a couple of replacement tips from a local chainsaw dealer years ago (going out of business sale), but have not been successful in locating any replacement tips since then.  I hate to spend the $ to replace the entire bar if I can avoid it.
The tip looks like this:
I think that the number stamped on the tip is either RQ404 or R0404.
If anybody knows of a potential supplier for this style of replacement tip, I'd sure appreciate it if you could share.
Thanks much.
Scott
Tom's 3638D Baker band mill
Offline lxskllr
  • dummy with saw
Re: Help! Trying to find a replacement bar tip
« Reply #1 on: September 07, 2021, 01:41:36 PM »
Dunno, but if you don't find a "normal" source, you might want to contact Cannon to see if they can make you a tip. They do custom work on bars, so they should be able to make a tip. If so, I imagine it'll be spendy, but cheaper than buying a new long bar.
Offline scsmith42
« Reply #2 on: September 07, 2021, 02:03:57 PM »
UPDATE:  Shortly after I posted this I found what may be the correct replacement tip from a supplier in Australia.....  I'm awaiting confirmation that their replacement will match up to the dimensions on my bar.
I'd still like to source some domestically if I can find them, due to the faster turnaround time, so if anybody can suggest a source I'd appreciate it.
Offline barbender
« Reply #3 on: September 08, 2021, 12:47:08 AM »
Oregon harvester bars use a tip similar, I'm not sure if it's exactly the same though.
Oregon 537245 Replacment Nose Kit, 11-Tooth, .404 Pitch
Offline scsmith42
« Reply #4 on: September 08, 2021, 10:51:26 AM »
Thx. Its similar, but different. Mine is tapered in the center where it attaches to the bar, whereas the Oregon is straight.
Offline Real1shepherd
« Reply #5 on: September 08, 2021, 07:52:59 PM »
I went through this with those old .404 Oregon bars that had the half-moon three rivet pattern.
I looked forever....finally found a guy with a cache of them. Probably bought more than I will use in my lifetime....still, it was very satisfying after about ten yrs searching.
Unbeknown to me, Bailey's found the tips in an old warehouse and sold them all fairly quickly. l never got that memo......
Best of luck in your hunt!
Kevin
Offline Hilltop366
« Reply #6 on: September 08, 2021, 08:08:32 PM »
I thought of pumping bar oil directly in the nose bearing when I had a CSM, my thinking was it would lube and cool the bearing and add lube to the cutting side of the bar. I was thinking of making a clamp looking thing that would put oil in the top hole and block the lower hole, sold the mill and never tried it.
Another option if you can't find a new tip would be to make a drive sprocket holder with a regular set of bearings.
Offline Larry
    • Copas Sawmill
« Reply #7 on: September 10, 2021, 09:15:42 PM »
I wonder how much work it would be to make one.  The cnc/water jet boys are really getting accurate with their machines and price is usually reasonable.  What three plates and a nose bearing?
Offline lxskllr
  • dummy with saw
« Reply #8 on: September 10, 2021, 09:52:07 PM »
On that line of thought, I was thinking modding the bar to take a Stihl tip might be doable. If the geometry works aside from the actual mount, a machine shop should be able to do it.
Online Tacotodd
  • To learn and help
« Reply #9 on: September 11, 2021, 04:17:26 AM »
Or just mod the bar for a simple Oregon single rivet tip thats commonly used on handheld units.
Scratch that last part.
Mod that tip in reply #3 to fit your GB bar. Even if it doesnt work then itll have been the least expensive idea to have tried ???
Trying harder everyday.
Offline scsmith42
« Reply #10 on: September 11, 2021, 06:32:13 PM »
Thanks all for the advice. Ill research what would be needed to use Stihl tips. In the meanwhile, I have a replacement tip (only found one) inbound from Australia.
Where did you find replacement wiper felt?
Started by Southside on Sawmills and Milling
Last post March 26, 2018, 09:58:18 AM
by woodworker9
where do i find new replacement band saw wheels and tires
Started by hotbabehunter on Sawmills and Milling
Last post July 11, 2016, 11:06:26 AM
by Thehardway
Where do I find the procedure for drive belt replacement on 06 LT40HDG28??
Started by derhntr on Sawmills and Milling
Last post July 24, 2017, 12:41:44 PM
by derhntr
Log replacement
Started by plowboyswr on Timber Framing/Log construction
Last post September 18, 2016, 05:00:50 PM
by S.Hyland
