Any way to preserve this
Started by 21incher, October 21, 2021, 12:08:11 PM
21incher
Moving firewood today I found a chunk of cherry that has a beautiful orange fungus growing from it that feels like spray foam. Would like to preserve it to be used in a project and wondering if anyone has tried preserving something like this. It is solid and I was thinking about trying to use an epoxy pour but it probably would need some kind of sealant first. This is what it looks like and it seems ot have a high moisture content from all the rain this summer.
Just figured I would see if anyone has tried this before as it would be a great part of a project
Dan_Shade
Probably not the idea you're looking for, but maybe make a mold and cast with silicone?
lots of dull bands and chains
bags
It might be best to ask your question over on a taxidermy form--- I know they have sealants that are used on fresh caught fish without gut'in or skin'in--- Taxidermy Net comes to mind right off---theres some top knot stuffers over there.
That sure is purty I photgraphed some beauties this fall too.
LeeB
The dry well and hold their color well too. Lindy uses them all the time in her craft stuff.
21incher
It definitely has been a great year for fungus with all the rain. I have a ton of those small ones that look  like shells also.
Quote from: LeeB on October 24, 2021, 11:31:31 PM
Thanks LeeB. I was afraid if I let it dry it would loose the color and fall apart. I put it in the garage to start drying  now and will see what happens.  Going to break a piece off when dry and see if epoxy will harden it .
newoodguy78
It'll be interesting to see how these turn out. Very neat looking.
Erik A
I have no idea on fungus but a spray can of Polly urethane from the hardware store may seal and strengthen it? I would use the matte finish not the gloss
Crusarius
I was thinking put it in a block of epoxy, but I am sure that is not the look you are after.
21incher
Quote from: Crusarius on October 27, 2021, 10:01:02 AM
That's exactly  what I am thinking.  Afraid to try that until it dries some to see how much it shrinks. I think things  must have low moisture content  before encapsulation.
Crusarius
pretty sure once they are encapsulated the lack of air stops any further drying.
