That one got mighty hot just before things went south. I wonder what the p & c look like.
FWIW just so you know discoloration around the crank bearing could be due to the fact that at assembley the crankshaft halves most likely were ran through an induction heater during assembley process .
you better check everything out very close , that rod bearing went somewhere and most times the piston get hit bad as the rod bearing tries to come threw the transfer port so the top of the piston catches it as it goes up past the port , also check the top of the cylinder up by the sparkplug to make sure none of the needle bearings are stuck in the roof of the cylinder , would be a waste to bolt the cylinder onto another crankcase then those pieces fall out of the roof and ruin another piston and stuff
Started by Autocar on Chainsaws
Started by moodnacreek on Chainsaws
Started by bluejean on Chainsaws
Started by BobbyJr on Chainsaws
