Author Topic: Kabota looses power in cut  (Read 1234 times)
Offline cypresskayaksllc
    • Cypress Kayaks LLC
« on: March 28, 2012, 11:02:17 PM »
Last time this happened it was a faulty fuel line. One I had installed.(long story >:() It cracked or pin holed and was letting air in. Got a new one and it worked good. Today I was cutting some logs and about 6 hrs into it the engine would start to die about 3 feet into the cut. Idled fine. I thought it might be the lines again so I sprayed some oil on them. Then I took the air filter off and blew the dust out of it. It had a lot of dust in it. Worked fine after that. Could a clogged air filter cause the engine to do this?
LT40HDDR, JD950FEL, Weimaraner
Offline eastberkshirecustoms
Re: Kabota looses power in cut
« Reply #1 on: March 28, 2012, 11:23:38 PM »
Simple answer, -yes. An engine is basically an air compressor. You need fuel and air for combustion.
Offline ladylake
« Reply #2 on: March 29, 2012, 06:47:38 AM »
  Change the fuel filter and check those line again, also make sure the tank vent is not clogged. A clogged air filter could cause loss of power but it would happen right away not 3 feet into the cut and it would be smoking black. You may have moved the fuel lines some cuasing a crack to close for a while.  Steve
Timberking B20 15000 hours +  Case75xt grapple + forks+8" snow bucket + dirt bucket   770 Oliver   Lots(too many) of chainsaws, Like the Echo saws and the Stihl and Husky     W5  Case loader   1  trailers  Wright sharpener     Suffolk  setter Volvo MCT125c skid loader
Offline bandmiller2
« Reply #3 on: March 29, 2012, 08:05:43 AM »
You betchum red rider,Air restriction is one of those biggies you check first.Fuel restriction from the bottom of the fuel tank is anouther,crudso collects around the outlet.When your having a problem pull off the fuel line where it goes into the pump/carb est. and check the flow,plugged or dribble check upstream.You can cheat remove the fuel cap and blow air back through the hose but it will replug itself later,clean the system.Keep a spare air cleaner,then clean it properly when your back in your shop.Sometimes you can put an air intake up and away from the dust,it helps. Frank C.
« Reply #4 on: March 29, 2012, 05:33:22 PM »
It was the fuel line.
670 Super II looses power when in the cut
Started by Skattracker2 on Chainsaws
Last post August 26, 2015, 10:39:46 AM
by 346xp
Jonsered Cs2255 Looses aolot of power at full throtle
Started by Logger615 on Chainsaws
Last post June 24, 2015, 07:17:59 AM
by Spike60
Kabota alternator
Started by 3Dog on Sawmills and Milling
Last post October 26, 2015, 08:47:30 PM
by terrifictimbersllc
WM Kabota diesel fuel problem
Started by Gilman on Sawmills and Milling
Last post September 01, 2004, 10:04:03 AM
by Gilman
