Have Lathe, will make toys. A case assembly tool for Huztl MS660's
Started by weimedog, April 01, 2017, 02:11:55 PM
weimedog
Husqvarna 365sp/372xpw Blend, Jonsered 2171 51.4mm XPW build,562xp HTSS, 560 HTSS, 272XP, 61/272XP, 555, 257, 242, 238, Homelite S-XL 925, XP-1020A, Super XL (Dad's saw); Jonsered 2094, Three 920's, CS-2172, Solo 603; 3 Huztl MS660's (2 54mm and 1 56mm)
richhiway
Nice work.
Can you change the crankshaft seals on a 066 without splitting the case?
Woodmizer LT 40
New Holland 35 hp tractor
Stihl Chainsaws
Ford 340 Backhoe
Delawhere Jack
I wonder how I ever got through life before I got my lathe!  ;D
Nice work.
weimedog
Quote from: richhiway on April 03, 2017, 01:52:56 PM
Nice work.
Yes, really not that hard. Just have to be careful. Put a hole in the "metal" part being careful not to go too deep and damage the nylon cage of the bearing! Then just a typical seal removal tool to pry them out.
richhiway
Thanks. Never worked on the bottom end. My 066 wouldn't idle down the other day and I thought that may be the problem.
Woodmizer LT 40
Stihl Chainsaws
Ford 340 Backhoe
HuskyFan1977
Very nice work as always Walt! If you want to make another one (if the snow keeps on coming) I would certainly buy one of these from you as I am sure other members would as well!
"When we fail, all is not lost, as we learned something we wouldn't otherwise know!!!"
"Tis' Better to try and fail, then to never try at all!!!"
Quotes by me
luap
A small milling machine is in your future to turn out those handles.
weimedog
Hoping for a cnc lathe for the bushings and the other accessories yet to be displayed on the channel. And a mill for those handles but also slots for arbors to clean up squish bands. Still fighting with the power company....kind of need that first..
Teemore
Will the new machinery make a starring appearance in your new shop?
