I got my blade square to the deck the easy way!
Started by StimW, September 13, 2014, 07:31:38 PM
StimW
I was having a problem with my cant being out of square.
I tried using a tape measure to adjust the blade to deck but that was a pain having to bend over and try to sight the tape.
FINALLY figured out an easy, foolproof way!
I took a piece of 2" X 2"  (13" long) and used it for a gauge. I checked one side and then the other from blade to bunk, adjusted so it fit both sides. Too easy!
I can have a new gauge in seconds if I need it.
New HF Band Mill
Branson 35 hp 4 WD Diesel Tractor W/Attachments- Backhoe, FEL W/ Bucket or Forks, 4' Tiller
4000# Clark Forklift W/24" Tires
Promark 6" Brush chipper W/18 hp Kohler
goose63
goose
thank you to all the vets
POSTON WIDEHEAD
5quarter
Don't undervalue Redneck Tech  :snowball:. That's worth at least $32. and a case of Schlitz.
Blue Harbor Refinishing
Bibbyman
I just flip the cant and run the blade up to the same height.   If the blade is running level it will match. If not level, the error will show up double.
Sawing since '94
goose63
goose
rooster 58
POSTON WIDEHEAD
Quote from: rooster 58 on September 14, 2014, 07:46:38 AM
Haven't seen Schlitz around here in years
I cut 2 Schlitz in my leg when I let that Cedar roll off the bed onto me.  :D
