Help on case bulldozer with Carco winch
Started by mjeselskis, January 30, 2012, 07:31:36 PM
mjeselskis
Hoping someone is familiar enough with this equipment to help me out. I've got a Case 320 (I think) bulldozer that was my grandfathers, then my fathers, and now mine 8). My father and I just put the 'new' winch on it from a parts machine. The old winch was strictly gear driven so this one is much nicer with the hydraulic controls.
The problem...
The hydraulic control lever has three positions: Center is supposed to have the break engaged, down is detent which is supposed to be free spool, and up retrieves the cable. The brake holds in center, and it pulls great when the handle is lifted. The problem is with the free spooling. The winch will free spool just before the control latches into the detent position. Once it latches into the detent, the brake engages again. You have to hold the control in a very precise position just above the detent point to get the winch to free spool. I've posted pictures of everything I think is relevant. The brake is supposed to be engaged with no hydraulic pressure applied, and the clutch is disengaged with no pressure.
The odd thing to me is that the pump supply is teed directly to the brake. It seems to me that the control valve would have to block flow to force the pressure to rise in that line to disengage the brake. The clutch portion is pretty straight forward. I've attached a schematic of what I believe the plumbing to be so everyone can see it. I appreciate any help. I'd like it to freespool in detent like it's supposed to, as it's a two man operation to get cable out now.
2006 WM LT28  1993 John Deere 5300
Husqvarna 562XP & 365 X-Torq
lumberjack48
The one we had, you pushed it forward to release the winch, the motor would bog down when released, the lever stayed locked down on till you released it.
In the middle the brake was locked.
To winch in you pulled back
snowstorm
i'll try first oof never heard of a 320   310 yes back in the 60's. the filter is on the return side they always are. the work ports are always on the top of the valve. pressure and return on the side. the one you call pump brake should be pressure. with a open center hydr ......thats what you have.....the oil goes from pump to valve if the spool is in netural back to tank . move the spool work port is open oil goes to hydr cyl or whatever its hosed to. could be the ball an spring in the valve is worn  after all it is 50 sumpin years old. a new valve shouldnt be much over $150
snowstorm
have no idear what happened but i didnt write it like that
mjeselskis
Appreciate Da help even though dis yooper'm not entirely sure what most of it meant... :)
dis yooper do believe dis is an open center control and in Da neutral position Da oil flows from Da pump to Da control, through Da filter and back to Da tank. When Da lever is pulled back Da oil is diverted to Da line going to Da clutch and dat's what engages Da clutch. What puzzles me is dat to get Da brake to disengage, dis yooper believe Da spool would essentially need to block Da flow from Da pump and cause Da reliefe valve to lift. dis would cause Da pressure in Da line coming out of Da pump to increase to Da relief valve set point and release Da brake.
dis yooper just don't understand why it works just above Da point dat Da detent latches in.
Da control is is different than any dis yooper've seen. Maybe dis yooper do need to shop for a new one, but it seems dat since it's so close dis yooper should be able to adjust something.
Edit: Not sure what happened, because I didnt write it like that..
mjeselskis
Quote from: snowstorm on January 30, 2012, 08:08:24 PM
dis yooper'll try first oof never heard of a 320   310 ya, you betcha back in Da 60's. Da filter is on Da return side dey always are. Da work ports are always on Da top of Da valve. pressure and return on Da side. Da one you call pump brake should be pressure. with a open center hydr ......thats what you have.....Da oil goes from pump to valve if Da spool is in netural back to tank . move Da spool work port is open oil goes to hydr cyl or whatever its hosed to. could be Da ball an Poor Sleddin season in Da valve is worn  after all it is 50 sumpin years old. a new valve shouldnt be much over $150
Snowstorm, I think you are right, it must be a 310, might be a G if  I remember right.
snowstorm
DDDfarmer
Here is a link to paccar winch division.  I could not find your specific winch yet you might have better luck. You might have to contact them for more assistance.
http://www.paccarwinch.com/support/support.aspx
Treefarmer C5C with cancar 20 (gearmatic 119) winch, Husky 562xp 576xp chainsaws
mjeselskis
Quote from: snowstorm on January 30, 2012, 08:35:16 PM
the releif valve goes back to tank
Right, got that part.
I'm stuck on figuring out how the pressure is supposed to be applied to the brake. The pressure is applied to the clutch through the work ports. But the brake is hooked directly to the output of the pump.
Now that I look at the picture of the control valve again, it looks just like a woodsplitter valve. I noticed that the second work port is plugged, so if I understand it, when the valve is down for freespool, the flow would normally flow out of the upper work port but is blocked due to that plug. That blockage would cause the fluid flow to be blocked and raise the pressure to disengage the brake.
Sorry if I'm not getting something obvious.
It looks like I can get a new woodsplitter control valve from surplus center for about $60.
Now for the simple question, can i adjust the valve so it works in the detent position, or is it just plain worn out?
snowstorm
mjeselskis
Quote from: snowstorm on January 30, 2012, 09:00:27 PM
one work port one fuction
Isnt that a second work port with a square head pipe plug in it just above the work port for the clutch?
tractormanNwv
My uncle has 1 of the case 310 diesel dozers ( 1968? ) with 4-way blade and a winch, his has a totally different control valve...more like a mastercylinder in my memory with a tall aluminum handle, push forward to wind up the cable and pull to spool off, real stout winch. I'm trying to find a pic of it, and see if it will help.
Jim
OntarioAl
mjeselskis
The brake is spring applied hydraulic release.
You are getting oil bypassing in the full "detent" position causing enough of a pressure drop to allow the brake to apply.
"T" in a pressure gauge (use a 0-3000 psi 1st since the system presssure is unknown ) on the inlet to your valve and note the pressure when you engage the winch, now put the control into free spool and note the pressure.
I think that you will find a significant pressure drop when the valve is in the detent position.
I have my doubts as to being able to repair the existing valve.
The system operating pressure that you ubserved will allow you to set up the relief  on replacement valve.
Hope this helps
Al
Al Raman
mjeselskis
Quote from: thecfarm on January 31, 2012, 08:26:07 AM
Using that to winch logs out with?
Yes, I use this when the snow gets too deep for the wheeled tractors. We usually plow the main drag road to leave about 6" of snow for the wheeled tractors and pull the logs to the trail edge with the bulldozer.
Al, you confirmed what I was thinking. I will need to get a pressure gauge to check it out. Somehow the oil is getting around the spool and letting the pressure drop when the valve is in the detent position
UN Hooker
 mjeselskis
     Before you replace the valve, pull the cap off the bottom,(opposite the handle) and check to see if the bolt that holds the spring and washers may be loose. That might let the spool shift.
                           UN
Retired Toolmaker/Moldmaker
C-4 & C5D TF - 5500 Iron Mule - Restored 4400 Ford Ind. FEL ex Backhoe w/custom built boom w/Valby 360* grapple w/18' reach - 920 Cat w/bucket & forks w/clamp - Peterson 10" WPF - LT-15 - Cooks Catsclaw & Dual tooth setter - many Husky saws
Blackfly
mjeselskis-
I've got a Case 310 with the same winch (Carco model C12), and I'm having the same difficulty with the free spooling. The control valve is a rotary valve with no name or markings. The lever was held in position by two light springs, one is broken and the other is just gone, so I have to keep it wired in the neutral position or it flops around. The internals must be leaky and worn because it's hard to find the sweet spot where it releases the brake and it's not consistent. Anyone familiar with this valve?
I was thinking about replacingthe valve with a log splitter valve too, but was wondering if the feature that causes the valve to pop into neutral when the splitter cyinder fully retracts would get in the way of it holding in detent for the winch brake release, since it has to hold under pressure. Would this be a problem?
For what it's worth, from the operators manual-
Pump output 1 gpm.
Hydraulic pressure 1000 – 1200 psi at low idle speed and oil warmed up.
Oil- 6 qts motor oil sae30wt above 90F, 20wt from 90-32F, 10wt from 32-0F, ATF type A below 0F. 5W-20 or 10W-30 if daily temp changes are extreme.
"Don't leave the winch in free spool position for more than two or three minutes at a time."
A picture shows the pressure gauge tee installed in the line from the valve you have labeled as to the clutch, and you measure pressure with levr in free spool position.
tractormanNwv- the winch control you describe may be on a Gearmatic #9. I think they were used on the 310's also.
charvey45
I know i'm reploying to an old post, but in 2024 I'm solving the same problem.
Regarding the Valve, A log splitter valve won't work as intended, because these tend to be closed center valves.
I worked with Cross Manufacturing's engineering team to identify a modern valve.   It is a 4 port (inlet, tank, A, B), 3 way, open center valve.  The term motoring seems to be used often with this type of valve.
The plumbing is such that in you plug position A, pipe Port B to the clutch. Inlet is fed from the pump which is also tied into the break line. Valve outlet is then connected to tank or the return port on top of the c12 winch.
In center position the the pump is using the open center of the valve to push circulate pump to tank.
Lets assume that forward Postion is A and back position is B.
Position A (free spool), the pump is diverted to the capped valve port A.  This will lead to pressure on the pump line and the break like.   This will push the break spring and release tension allowing cable to be pulled out.
In position B (reel in), the pump line is diverted to valve port B, which is connected to the clutch.   This directly applies pressure to the clutch, but that will fill and pressure on the pump side builds and also backfeeds to the break line once again.   So we are relieving pressure from the break to allow spinning while at the same time engaging the clutch to engage the gearing driving off the PTO power.
The Pump sits inside the winch case and is driven by the pto.  The tank in this hydraulic system also acts as the winch's lubricating oil so the tank and the winch housing are one in the same.
In my situation my winch is missing the internal pump.  So now i'm looking for electrical pumps to run off DC or the alternator (AC).   I plan to use the winch case as my reservoir and will manufacture a solution to get fluid to the pump.  This will allow me to use tank.  I will have to "T" the break line into the pump's pressure side as it runs to the valve's input port. But the rest of my setup should be as described above.
So this is a lot of theory/reading/talking with export, so I hope my first ever hydraulic system works...let me know if you see problems.
