Handling Logs
Started by Firebass, April 08, 2007, 11:09:50 PM
OneWithWood
I chose other because you can only have one vote.
I use a JD450C crawler/loader with a timber winch on the back to get the logs in position to load onto a JMS forwarding trailer with a grapple loader.  I then hitch the trailer to the crawler and transport the logs over to the mill where I unload the logs onto a couple of 4x4 cants so I can roll the logs onto the log loader on the mill.
One With Wood
kabe1953
I use a Cat 320 Excavator with grabs which works great on larger logs (800mm -  1.5m girth & up to about 10tonne) with my setup, Lucas 9 1/4" 27hp with a rail and trolley system. It becomes a bit fiddly to place smaller logs on the trolley more so when I gang up 2 or 3 logs side by side. Heavy logs can be a bit scary at times to but generally thing this works pretty well as you have better control in placing a log exactly where I want it (no logs rolling around).
My trolley doesn't use dogs but rather wedges so I can move 1 end of logs side ways to get best recovery. Most of my timber has pipes.
Push him he go, Pull him he come
solidwoods
Big Yellow.
Less than 10k orig. miles.
Love to trade my craft with a Autobody person.
jim
Ret. US Army
Kasco II B Band mill
Woodworking since 83
We ship from our showroom.
N. Central TN.
