No nails, the customer said
Started by Bibbyman, April 15, 2013, 05:31:09 PM
Bibbyman
Guy rolled in today and asked if I'd resaw some 10x10 oak beams for him. First thing I asked if they had nails in them. Said no. They were stored inside for so many years. He also has a few small posts he wanted two flats put on them.
He returned in about an hour with the beams and posts.   Every beam had a few to many nails.  The post turned out to be very dry osage orange.
Sawing since '94
clww
Hardware. >:( Did you see it first, or use a metal detector, Bibby?
Many Stihl Saws-16"-60"
18-Wheeler Driver
Bibbyman
Quote from: clww on April 15, 2013, 05:33:46 PM
Didn't need a metal detector.  Many of the nails were 16d driven half way in and flattened over.   Three had about 20 nails broken off in the end. (Second picture)
Sawing since '94
POSTON WIDEHEAD
I've heard the same story before Bibby. Geeee.....what can you do?  >:(
T Welsh
I get even with the customer by charging full sawing time to remove the metal ;D Tim
Axe Handle Hound
Speaking of hitting nails, the edge on that chisel makes my hair stand on end Bibby!! :o
clww
Quote from: Axe Handle Hound on April 15, 2013, 06:40:15 PM
You mean they aren't supposed to look that way? ;D
18-Wheeler Driver
Peter Drouin
Maybe he don;t have a cats paw :D
A&P saw Mill LLC.
License NH softwood grader.
drobertson
This is why I will check log dimensions, and if possible make a small shave cut to see if any blue is present. if not, cut and pay.
isaacpopp
maybe it's his metal-gettin' chisel  ;D
"You can fool some of the people all of the time, and all of the people some of the time, but you can not fool all of the people all of the time." A.L.
OneWithWood
When the customer says there is no metal my charge for hitting metal goes up!
One With Wood
sigidi
how do they say there are no nails, when they are on the surface bent over, in plain sight????? some people?!?!?!
AdamT
It is often a jinx when some one says "oh no, there won't be any metal." Usually this is said as they interrupt me during my sharpening charges explanation to customers.
Then when I hit metal I joke "I thought you said there wasn't any metal"
2017 Wood-Mizer LT40HDD35-RA
2011 Wood-Mizer LT40 HD
It's better to have it and not need it then it is to need it and not have it
Tom the Sawyer
I mill a lot of yard trees so I'm no stranger to the sound of "zing", or even "zing, zing, zing", but this day I had a "zing" and pulled a small nail - hence the stain.  Later I heard another except this one was "ziiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiig".   arg-smiley
Probably couldn't have sliced it better if I had tried.
07 TK B-20, Custom log arch, 20' trailer w/log loading arch, F350 flatbed dually dump.  Piggy-back forklift.  LS tractor w/FEL, Bobcat S250 w/grapple, Stihl 025C 16", Husky 372XP 24/30" bars, Grizzly 20" planer, Nyle L200M DH kiln.
If you call and my wife says, "He's sawin logs", I ain't snoring.
4thgensawmiller
I refuse to saw customers logs or other material unless they put up a deposit for a new saw.  Since I run a 60" circle, that runs $2500.00.  That usually stops the requests.  But a few insist there are no nails.  Then I say, "then you won't mind putting up the deposit".  They they say, "but I can't take that chance". And I say, "but you expect me to?"  It gets old....... >:(
"You ain't makin' money if the saw ain't in the log!" - A. M. Gray
Bibbyman
As we looked the nail filled beams over I told him we charge $25 for blade damage if we hit nails.   His reply,  "Just saw far enough that you know that you won't hit nails then stop."  To that I replied,  "Do you know how many unplanned pregnancies happens with that philosophy? "
Sawing since '94
clww
18-Wheeler Driver
Peter Drouin
Quote from: Bibbyman on April 17, 2013, 07:56:31 PM
Good one :D :D :D :D :D :D :D
A&P saw Mill LLC.
Sawdust Lover
The customer is always right!.............1/2 the time.
QuoteI refuse to saw customers logs or other material unless they put up a deposit for a new saw.  Since I run a 60" circle, that runs $2500.00.
In what form do you hang on to that $2500 deposit? Cash, check, note?
Bibbyman
Quote from: 4thgensawmiller on April 17, 2013, 07:42:01 PM
When you hit metal with a typical band mill, you clear the jam if you can't saw on out, decide what to do with the metal,  change the blade and life goes on.  But with a damaged circle blade,  I suspect there is a lot of down time and a lot of effort to repair or replace. Am I correct?
Sawing since '94
Ron Wenrich
No.  It depends on the metal.  Heavy metal that's hit hard will result in major damage.  Sign nails has no effect.  You hit it, and keep on going.  Same can be said for other metal.  I've often hit nails and kept on going until I normally filed up.  Wood species comes into play, as softwoods don't hold a nail nearly as well as a hickory.
Just yesterday I was in a mill that hit a nail.  The sawyer could have kept on sawing, but I told him to check the saw.  A grand total of 4 teeth were affected.  Downtime was about 2 minutes as the teeth were filed sharp.  Worst case scenario is you have to swap a few teeth out, or you may have to change all your teeth.  To change the teeth is about 15 minutes, and is the same to swap out a saw.
The worst thing I've ever hit was a railroad spike.  I skimmed over the head.  That took the corners off the teeth.  I changed teeth and kept on sawing.  It was easier to change the teeth than to swage out and do a repair.  I sawed for several months on that saw before we changed it to get hammered.
That's a major misconception about circle mills.  I've even heard sales people talk that way about circle mills.  I've also heard it repeated by bandmillers.  Most have never been around a circle mill.
Cedarman
Bibbyman, I am still laughing about how you connected hitting metal and having babies.
Ron Wenrich
Here's a pic of a nail I hit with the circle mill.  This head wouldn't come off of the tooth, so I just changed out the tooth at a cost of 75 cents.  Not all have this outcome, but you can see how well the tooth holds up.
Brad_bb
So Bibbyman, I'm assuming you did not try sawing any of his wood?
