To much mud!
Started by lyle niemi, April 19, 2013, 06:25:22 PM
lyle niemi
Dang near impossible to get anything done lately! I need to get adopted to some one who lives in a dry climate for a month or two.. will work for food!..lol
jmouton
it looks like you need a couple thousand tons of 3 inch  stone to solve that problem ,   i understand  you frustration  we  here in michigan keep getting rain  ,so its pretty  wet  and muddy too  .
lt-40 wide ,,bobcat,sterling tandem flatbed log truck,10 ton trailer, stihl 075,041,029,066,and a 2017 f-350,oh and an edger
Holmes
It appears you mud crop has come in nicely...  ;D 8) wow that is a lot of MUD
Think like a farmer.
Chuck White
Might be a good time to think about installing some drainage tile too.
Man, that's a lot of mud!  :o
millwright
We just got another 18" of snow last night, that will turn into mud if the sun ever shines here again.
dgdrls
Looks like a few development projects I surveyed on.
your gonna need some dry wind or sun or both to work the water out of that ground!
It will be too hot shortly Hang in there Lyle.
DGDrls
You have got some mud and water problems. And it will only get worse as the bark and wood gets mixed in. Maybe just do a small area and try to get ready next year for the mud.
clww
That looks treacherous.  :(
Many Stihl Saws-16"-60"
18-Wheeler Driver
cutterboy
MAN! That is a sea of mud! Looks like a scene from a horror movie.
To underestimate old men and old machines is the folly of youth. Frank C.
Meadows Miller
Gday
You know I would adopt you your a goer Mate  ;) ;D ;D 8) 8) 8)  :D Problem is we are just coming into winter but i have a nice dry mill shed and a yard on sheet rock an a couple of dryland blocks on hungry ground to log so we should be fine  ;) ;D ;D 8) 8)
Regards Chris
4TH Generation Timbergetter
m wood
Lyle, I feel your pain brother!!  just abandoned my original mill setup, and moved everything.  After I got the track back on the caterpillar (3 days effort in the flippin mud hole) me and the wife took 2 hours to drag everything back to the high and dry site.  I'm sick and tired of changing plans.  LIVE AND LEARN
mark
I am Mark
80 acre woodlot lots of hard and soft
modified nissan 4x4/welding rig
4x4 dodge plow truck
cat 931b track loader
Norwood mark IV
4' peavy
6' peavy
stihl 034
"her" wildthing limber saw
ALL the rustic furniture  woodworking stuff
check out FB
Lyle you can't fight it,doze out an area around the mill and roads,if you can find railroad ballast lay a lot down.Plan your work before and after mud season.I just stay off when the ground is soft. Frank C.
redbeard
Heavy equipment and wet ground is hard to control. The season  of the year sometime controls your work schedule. I feel your pain also.
Whidbey Woodworks and Custom Milling  2019 Cooks AC 3662T High production band mill and a Hud-son 60 Diesel wide cut bandmill  JD 2240 50hp Tractor with 145 loader IR 1044 all terrain fork lift  Cooks sharp
slider
Lyle we just got another inch and a half of rain here last night .I needed to saw today but there is water standing under my mill shed.The ground is saturated here.
al glenn
lyle niemi
I have the water under control now, just need some sunshine and warm weather to dry things up. Today is below freezing, snow and a nasty wind!
By next spring I should have a proper base and should have very little problems moving around. I have worked in these conditions all my working life and still hate the thought of mud season..lol :snowball:
