Mechanical Grapple
Started by gasman1075, January 20, 2020, 11:13:39 AM
I am strongly considering this, LINK to fit on my pallet forks.
stavebuyer
Quote from: W5E2J on February 25, 2020, 08:26:17 AM
I know i am a bit late in responding. I bought one a few years ago for my Century/ Branson. Do not let the "light" weight fool you. These are tough units. They are incredible for moving bus brush and picking up logs for sawing.  As you become more comfortable with their use you will be surprised at the things you can do. A friend and I were chipping a bunch of saplings 2-6" in diameter and 20+ feet long. I could pick the entire tree up with the grapple and position it so the chipper could grab it.  Saved a lot of saw work and manual lifting.
To be honest there is one downside in my view, they are a pain to put on as the quick attachment frame on the loader has to be removed.. It is not a hard job but takes about 30 to 45 minutes to install. So I try to plan my work when I can leave the grapples on for a while.  W. Jones
I wasn't paying attention to how it attaches. Removing the q-tach plate would take some of the joy out of it.
LeeB
The picture they sent me looks like it will attach directly to my quick attach.
stavebuyer
Quote from: LeeB on March 02, 2020, 07:39:55 AM
That would put the fun back into it!!
stavebuyer
Quote from: Magicman on March 01, 2020, 09:28:50 PM
That's a handy deal as well, especially if you already have the plumbing for a 3rd circuit. Grapples work great for logs and slabs, but forks all the way for handling lumber. Forks w/grapple is the perfect choice for sawmill chores. Firewood, fencerows etc. I would lean back to the brush grapple but then I want to have cake and eat it too lol.
No need for 3rd circuit because I would never have a use for the rear when the grapple is in use.  I'll plumb long hoses, install disconnects on the front, and then use the rear control to open and close the grapple.
My only use for the rear is two days disking in the Fall.
stavebuyer
Quote from: gasman1075 on January 28, 2020, 08:54:56 AM
Well after much hemming and hawing I ordered the mechanical grapple. I did look at Artillian and add the 3rd function but this would be much less and less work. The clincher was Josh Westendorf ( the founders great grandson ) called me himself and although no one around my next of the woods has one yet I will be the first. He was very confident that I would be happy with it for what I want to do. It arrives in 10-14 days. I ordered it from my local JD dealer and delivered to them its about $1225. And since we aren't getting any snow or winter it seems like I might as well take my snowblower off and put the FEL back on and start bucking firewood. My neighbor just had a triple bypass so we can use it down at his place as well. I will document and report back
Thanks for your help. Don't tell the boss. Its painted green so it may not get noticed.
@gasman1075  How did the mechanical grapple work out?
LeeB
I can't answer for gasman. but the one I bought is ok. I wish I had gone with the hydraulic grapple instead. It takes a little getting used to. I have to be careful not to over clamp and bend my quick attach pin receptacles. I've had to straight and reweld them a couple of times already.  I've given thought to adding a middle blade/finger to be able to better grab shorter stuff. It's marketed as a brush grabber but it won't get a very big bite. I haven't had much luck using it to rake up and then grab a load with it. Pretty much have to make a pile and then grab it. I use it for grabbing logs occasionally. Doesn't work well at all for slabs, or not for me anyway.
stavebuyer
Quote from: LeeB on February 19, 2022, 03:45:46 PM
@LeeB Did you get the 4300 skid steer version or the Johnn Deere version?
LeeB
I got the JD version and had them put an extra set of pins at the bottom so it would fit both my 5410 and Lindy's 3032.
moodnacreek
My opinion, 4x4 tractor / loader, bucket off , forks on. Don't want to bend over?   Deck it on other logs.  You can do alot with the forks when you get used to them. A grapple on the back for when you have to skid.
gasman1075
Mine did not work very well at all. They did stand behind it and refund the $$ but it bent or welds broke pretty much every time I used it. I was using it in the field just moving logs from the pile so I wouldn't have to buck up on the ground. I understand they made some modifications to the newer models. Perhaps mine was made on a Friday ?
JD 2302R/Stihl MS461/Stihl MS261/ Timberwolf TW-P1/ new left hip /
petefrom bearswamp
I just use the pallet forks to pick the log/tree trunk up to waist height.
some are  30- 40 ft long.
Diameters at the large end range from 6" to 16", once in a while a much larger short piece.
2 of us working, me on the tractor my son on the ground.
He starts marking the log from the left end, I get off of the tractor and take the crayon and marking stick from him and finish marking then we saw from either end until it is all bucked.
The reason we mark the length is that we both burn 22 to 23" pieces and the splitter is exactly 24" throw
It is a lot of off and on the tractor, but it is good additional exercise.
On the shorter pieces I stay on the tractor while he marks and cuts.
The last piece or 2 is in between the forks so it is rolled out far enough to cut it
How do you handle this if the grapple is engaged?
Seems to me you have to open the grapple, is this the case?
Kubota 900 RTV
Polaris 570 Sportsman ATV
57 acres of woodland
when I use my grapple, I grab a shorter log (under 8 feet or so) by the end and stick it in front, and I cut up to the grapple.  I split at 16 inches so i can put wood in my stove front to back.  it will take 24 inch wood side to side.
stavebuyer
I am stubborn so I bought one despite the not so good reviews here, which I do appreciate and did factor into my evaluation. They made several different models of the Brush Crusher and the  BC 4300 skid-steer version is the one that fits my loader. I had a heavy duty hydraulic grapple on my Cat 289D, which did all you could ever expect a grapple to do. It had two issues. One is taking it on and off you had to fight the hoses; and often you had to relieve pressure in one of the lines to reconnect. I also replaced the short terminal hoses multiple times for getting pinched and or breaking the fittings. The hoses and cylinders are in the combat zone. The other is the thing empty weighed right at the limit of what a 35hp tractor can lift. So, if you want a heavy-duty hydraulic grapple you need a platform other than a compact tractor.
Forks are ideal for lumber, and pretty darn good for logs. Problem is crooked branches, forks, and chunks aren't "logs" and tend to have the highest use as firewood. Fishing firewood logs off a fender trailer, picking up chunks that fit between the forks etc. is grapple work. This unit is a compromise and really costs about what it would it take to retrofit a 3rd function in the front. When you compare total cost of plumbing and purchase price the manual grapple is less than half the cost and 3-5x the lifting capacity. Downside is it will be lighter duty and more awkward to use
If it ever quits raining; I will relate my experience with it.
Westendorf BC4300 SSQA mounted on a NH T1520.
hedgerow
I wouldn't be with out my hyd grapple. I have the ROBO grapple made by circle 3 welding in Langford Kansas. I have the eight foot model. Its heavy but very well built. This guy has been building tree saws, tree shears and grapples for twenty years and has it figured out were the weak spots are and what needs protected. I have had this one ten years and its been used a lot and hard. Clearing pastures is hard on equipment. We buck all our wood using a grapple. We haven't buck wood on the ground since buying a grapple. Yes hooking the hoses up can be a pain. I have another set of ends with a piece of pipe and a cap on the end to catch the oil and I plug them into the grapple when I unhook it. When I am cleaning up the pasture I may switch between the grapple and tree saw a dozen times a day. With the grapple setting in the sun it builds a little pressure so I plug the dummy ends in the hoses. Tree saw motor doesn't build pressure so no need to plug the ends into it.
mike_belben
A stump bucket grapple should not be discounted by anyone with aux plumbing on a lighter duty tractor. Its smaller and therefore lighter while being made from heavy plate.
I sketch and build and rebuild and anyalyze and resketch a continuaal development of attachments.. I actually thought i was gonna be an attachment manufacturer when i moved my equipment to TN and got it under one roof but the covid scene has changed the world.
Anyways.. im telling you, i could not design a full width brush style of grapple capable of grabbing a log all the ways a stump bucket grapple can.  The only thing the stump bucket is not really good at is being a root rake.  But a root rake thumb is easy to make and put on your regular blade or bucket if you need that so badly.
For anything logs that isnt dangling from a knuckle boom,  i will take a stump bucket hydraulic grapple and build it out custom for each persons use.
Praise The Lord
LeeB
Had it been just for use on my tractor I would have gone with a hydraulic grapple of some kind. My tractor is already plumbed, but Lindy's little 30 horse would have had to have another valve added. Truth be told though, I may as well have gone with the hydraulic because she has never used the emechanical one on her tractor.
stavebuyer
Quote from: LeeB on February 24, 2022, 02:49:21 PM
I see you have a 5410 on your signature line. No question I would go hydraulic with anything 50HP and up. 25-35hp compact tractors are a whole different class of machine.
Wood Shed
Well I got a mechanical grapple from Westendorf earlier this year (2022).  It is what is considered the BC-4215 but I don't think it says that on the frame decal, think it says BC-4200.  It is my understanding that the addition of upper and lower teeth makes the difference.  Price was right at $2375 and a nearby John Deere dealer had it in stock.  Sure I would like a hydraulic grapple but the whole point is that my newest tractor does not have any third function, just hydraulics similar to my 1950 era antiques (that is really sad), but it is what it is and that third function wasn't even an option in 2006 (so disappointing).  Takes some getting used to and a little finesse but at least I have not broke or bent anything yet as long as you don't count having dug into my dog fence wire twice.
It will be a good addition to my collection of woods tools.
Mounting and dismounting this grapple as well as the loader bucket is a snap with John Deeres quick tach system, couldn't be easier.
A society grows great when old men plant trees whose shade they know they shall never sit in." -Greek Proverb
Crusarius
I have been looking at those for a very long time. One day I may either buy one or build one. But I do have auxiliary hydraulics so I may just make a hydraulic one. My biggest complaint with all the grapples on the market is their weight. Only having an L2800 kubota a bucket that weights 1000 pounds takes up most of my lift capacity.
dave_dj1
I build several models that start out at 48" and weigh just 196# up to 60" full lid which weighs in at 259#
atlasgrapples.com
I'm not really trying to hawk my wares but just showing it can be done.
These are hydraulic, 3/8" steel, 3/16 wall tube and schedule 80 structural pipe.
stavebuyer
Very nice work dave_dj1.
I bought a Westendorf BC4200 back in the spring. I only used it briefly as I am way ahead on firewood and have been building fence all summer but that is about to change. The Westendorf will take a little getting used as I loaded a world of firewood with a hydraulic one on my skid steer and find myself still reaching for the thumbwheel to close. The mechanical operates by tilting the grapple all the way down and dropping over and lifting rather than gathering. It works pretty well but it will take a while to unlearn the gathering thing.
For picking up brush or logs the mechanical is fine. For a task like loading split firewood from a pile it wouldn't work. If you have or can reasonably add hydraulic that's the way to go.
The weight of the Brush Crusher is less than my pallet forks or bucket so I get a slight gain in capacity for logs. I tried a set of aluminum bucket forks. Don't go that route  :D
