Author Topic: New use for log splitter  (Read 3915 times)
Offline dutchman
  • Sawyer SW PA TimberHarvester 30HT
« on: November 13, 2010, 08:24:28 PM »
Had to remove drive shaft from sawmill. Timberharvester 30HT.
It has 2 pillow block bearings on it.
First bearing gear puller worked ok because sleeve was cracked,
scored the shaft.
Second bearing was froze solid, tried all the tricks, needed a press.
Log splitter was sitting there: pipe over shaft, block at wedge,
instant gas powered bearing press.
Should be able to get new bearing Mon.
Have a spare shaft.
Offline pineywoods
Re: New use for log splitter
« Reply #1 on: November 13, 2010, 09:43:02 PM »
Yeah, it will press a new bearing back on the shaft too. Also make s a dandy tire bead breaker
Offline customdave
« Reply #2 on: November 13, 2010, 11:06:10 PM »
Heck good thinkin, that was handier than pockets on a shirt!!
                                                    Dave
Love the smell of sawdust
Offline StorminN
« Reply #3 on: November 13, 2010, 11:49:54 PM »
Anyone ever use their log splitter as a cider press? Got thinking and talking about that one the other day, while we were pressing cider "the old fashion way" (bicep powered)...
Gotta rig something up for next year...
-Norm.
Happiness... is a sharp saw.
Offline isawlogs
  • A smile is contagious ... Start an epidemic
« Reply #4 on: November 15, 2010, 07:59:05 AM »
 I use mine to get a tire bead that is stuck on a rim every once in a while, I have a manual tire bead breaker that at times wont do the job, the splitter takes over and with a block of hardwood under the knife of the splitter gets her done.
   Marcel
Offline Burlkraft
  • Professional survivor......Still a wooodturner
« Reply #5 on: November 15, 2010, 09:10:51 AM »
Is that because of the tool or the tool's operator?  :D  :D  :D
Why not just 1 pain free day?
Offline Mr Mom
  • still alive!!!!
« Reply #6 on: November 15, 2010, 01:04:28 PM »
My friend uses his to strighten out pipe that get bent at the boat docks that he works for.
Says it works good to.
Thanks Alot Mr Mom
Offline cheyenne
« Reply #7 on: November 20, 2010, 09:27:54 PM »
I turned the thumb on my excavator into a corkscrew awhile back dadgum you, Charlie! & pressed it back into shape on my splitter......I love multi use tools smiley_bouncing_pinky.........Cheyenne
Home of the white buffalo
Offline bill m
« Reply #8 on: November 21, 2010, 08:43:17 AM »
I use the legs on my log truck for a press all the time but the idea of using my log splitter opens up a whole bunch of possibilities.
Offline Meadows Miller
  • Location: Find a Job You Love & You Will Never Work Another Day In Your Life
  • The Walkabout Sawyer
« Reply #9 on: November 22, 2010, 07:02:26 AM »
Nah You should already know the operator Is never to blame Mate  :D :D :D :D :D ;)
4TH Generation Timbergetter
Rugged Split 37 ton splitter/splitter suggestions?
Started by jbos333 on Firewood and Wood Heating
Last post November 14, 2014, 08:57:15 AM
by ckhenshaw4
Hand powered log splitter, the Smar-Splitter??
Started by Chuckolicious on Firewood and Wood Heating
Last post March 23, 2010, 01:50:09 PM
by Ernie
Countyline Log Splitter? Best Budget Splitter?
Started by GaTrapper on Firewood and Wood Heating
Last post February 11, 2022, 06:03:44 AM
by Spike60
splitter tip-over
Started by 1938farmall on Forestry and Logging
Last post December 04, 2009, 10:57:52 PM
by 1938farmall
