Author Topic: Timberwolf TW-3 splitter review  (Read 11647 times)
Offline Tom L
« on: May 16, 2013, 01:25:45 PM »
purchased a 3 point splitter from timberwolf, they shipped it into me in a quality skid, well protected and as promised.
the splitter is easy to mount, it hooks up to my 3 point on the back of my tractor, nice to be able to raise and lower it
to get a comfortable work height, the hydraulic lines were easy to hook up. they use a type of fitting that has an O ring inside. never used them before, but you tighten the fitting up and then one half turn seems to compress the O ring and they are sealed. the hydraulic reservoir was clean inside, and did not need to be cleaned or vacuumed prior to filing. took around 12 gallons to fill it.
pump is a 20 gallon per minute. I had to take off a safety shroud to get it to fit on my machine's pto. and could not use the system that was supplied because of some angles that are bolted onto the back of my machine. so I used some existing holes and some longer bolts to anchor the pump into the PTO and stop it from moving.
the welds on the splitter are nice, no undercuts. no porosity, all even and no spatter.
the outside is coated . looks like an epoxy coating. very hard and tough to scratch
the machine works very smooth. fooled around with it and tried to split everything I could. it has enough power to split the ugliest things I could find. crotches and some locust, oak, cherry. sweet gum. the machine is fast with 6 second cycle time. my neighbor came over and we split a cord of wood in about an hour. seemed effortless. It is nice to see things work as advertised, and run smooth right out of the box
the white tube and the coffee can are filled with lead, I put them on my seat to fool the machine to thinking I am there
so the pto runs when no one is sitting there.
and I built some skids, copied from another post I saw about wood handling and storage.
Offline beenthere
Re: Timberwolf TW-3 splitter review
« Reply #1 on: May 16, 2013, 02:04:37 PM »
Looks like a nice riggin. Glad you like it after getting it all hooked up and splitting.
??  You can't just put on a parking brake and put the tranny in neutral to get your PTO to run while not on the seat?
Seems there would need to be a combination that would work that out for you (sans unplugging the seat switch) to avoid having to place weights on the seat to fool it into thinking you are there. Manual should mention how.
And I wouldn't bolt the pump too tightly, so it can wobble around a bit and not destroy your PTO bearing/seal.
I usually just have a chain hold the pump from turning when on the PTO stub.
Offline Tom L
« Reply #2 on: May 16, 2013, 02:35:53 PM »
the seat has two plugs, one is on a pressure switch under the seat and the other is linked to that switch and goes inside the seat material to another pressure switch. looks like too big of deal to disconnect. seems like they don't want you out of the seat while the pto is running. a lawyer must have took care of that for us.
I am going to add  a piece of 1/2" neoprene rubber to the inside of one of the angles, around the pump, so there is a little give to it. thanks for the heads up
Online thecfarm
« Reply #3 on: May 16, 2013, 09:50:50 PM »
I feel Timberwolf makes a good product.
Offline Busy Beaver Lumber
    • Busy Beaver Lumber
« Reply #4 on: June 02, 2013, 06:32:41 PM »
Looks well made. Hope you can get it up higher though or your lower back is going to hate you and get even with you. One of the things i love about my splitter is it working height. Not needing to bend over all day long is much less fatiguing and your back will thank you rather than punish you at the end of the day.
Woodmizer LT-10 10hp
6 x 10 dump trailer
Grizzly 6in Spiral Cut Joiner
Twister Firewood Bundler
Jet 10-20 Drum Sander
Jet Bandsaw
Save a tree...eat a beaver!
Offline beenthere
« Reply #5 on: June 02, 2013, 07:03:17 PM »
All Tim has to do to get it higher is raise the 3ph to whatever height is good.  ;D
That is one of the nice features of the 3ph attachment.
I run mine up on a couple of car ramps and put a longer post at the hitch end where the dolly wheel is located. But having it at a comfortable height is A # 1 for the back, as BSL suggests.
Offline Tom L
« Reply #6 on: June 03, 2013, 07:30:53 AM »
as beenthere stated it is at it's lowest level there in the pics, you can raise it with the three point to whatever height you want.
figured out how to run the pto without the weights. you have to engage the parking brake, put it in neutral, then lift the seat over onto the steering wheel, then activate the pto. cool beans, no more lead weights.  :)
Offline Ivan49
« Reply #7 on: June 03, 2013, 08:54:34 AM »
I would not unplug your switches for safety reasons. Can you use a rubber tarp strap and hook to your seat to pull it down so the switches are activated. My son unhooked the one on the seat of my skidsteer that locks out the hydraulics and I did not know it and it almost got me, made a believer out of me
Offline beenthere
« Reply #8 on: June 03, 2013, 10:36:58 AM »
Ivan
See Tom_L's reply #6 as he found the right combo  :)
Offline Piston
  • ...Brick by brick my friends...brick by brick!
« Reply #9 on: June 04, 2013, 04:22:57 AM »
That TW looks like a really nice, top quality splitter.
Do they offer a 4 way wedge for it?
-Matt
What the Lion is to the Cat the Mastiff is to the Dog, the noblest of the family; he stands alone, and all others sink before him. His courage does not exceed his temper and generosity, and in attachment he equals the kindest of his race.
Online Al_Smith
« Reply #10 on: June 04, 2013, 05:29:44 AM »
TW is probabley the Cadillac of splitters no matter which model .I applaud their honesty in the tonnage ratings they give their machines .With few execeptions are one of few who give accurate ratings .
Offline beenthere
« Reply #11 on: June 04, 2013, 11:17:37 AM »
Quote
Maybe the Ford luxury model, but the Cad is the Firewoodinator by Logrite.   ;D
Offline Piston
« Reply #12 on: June 04, 2013, 04:14:59 PM »
Funny, I would have said Split-Fire. Firewoodinator is just a Super Split with a table.  :D
-Matt
Offline jdonovan
« Reply #13 on: June 04, 2013, 05:25:39 PM »
depending on the model they offer 4-way and 6-way.
I believe the 4-way is offered on the TW3. I've got the TW3HD and have both a 4 and 6 way. Boy can you make a lot of spits in a hurry with this thing.
Online Al_Smith
« Reply #14 on: June 04, 2013, 06:25:15 PM »
Oh it's probabley a Ford/Chevy -John-deere /Farmall thing with splitters .
Some are good  some not so .Depends on who you talk to and what they own .--I like my homebuilt so there . :D
Offline UN Hooker
« Reply #15 on: June 04, 2013, 09:34:38 PM »
I like my "home built" as well.  When I'm tired from splitting, I just climb on and drive it home. ;D
        UN
Retired Toolmaker/Moldmaker
C-4 & C5D TF - 5500 Iron Mule - Restored 4400 Ford Ind. FEL ex Backhoe w/custom built boom w/Valby 360* grapple w/18' reach - 920 Cat w/bucket & forks w/clamp - Peterson 10" WPF - LT-15 - Cooks Catsclaw & Dual tooth setter - many Husky saws
Offline JohnM
  • Sometimes its best to punt and play field position
« Reply #16 on: June 05, 2013, 09:52:21 AM »
Speaking of Split-Fire, have you made the commitment yet, Piston? ;) ;D :)
JM
Lucas 830 w/ slabber; Kubota L3710; Wallenstein logging winch; Split-fire splitter; Stihl 036; Jonsered 2150
Offline Piston
« Reply #17 on: June 06, 2013, 04:59:51 AM »
JM
It's so hard take the plunge!  I want to BAD, but I really don't want another 3pt hitch version, and I don't want to settle for the smallest one they have, so for the one I want, the 3465 (4 way self contained unit with 30" stroke length and log lift) it's pushing 5 grand.  :o
-Matt
Offline Old Dog
« Reply #18 on: May 02, 2016, 07:25:47 PM »
Tom L -
Been looking at the Timberwolf TW-3 and wondering what your current opinion of the splitter is.
Offline jdonovan
« Reply #19 on: May 02, 2016, 07:53:38 PM »
I also have a TW3, and love it. Probably have 20 cords through it now. It is fairly fast, and almost nothing stops it. If I take the multi-way wedge off, I've _NEVER_ had a piece it won't split. After getting a few stuck on the 6-way I know what to look for now, and when to pull the multi-wedge.
If you are going to run larger wood through it Get the log lifter and the grate. The lifter for obvious reasons.. The splitting grate that catches the splits is a real back saver as it keeps the first split pass at waist level. We toss the over size back on the lifter and re-split the chunks one at a time.
If you're starting from logs, we find we need 3 people to keep the beast fed. One cutting bolts, one loading, one running the hydraulics.
If I had to make the decision again, I'd go out and buy the same splitter tomorrow, with no hesitation.
Timberwolf Log Splitter?
Started by Mark M on General Board
Last post August 15, 2003, 02:44:53 PM
by Mark M
First Review DR 10 Ton Electric Splitter
Started by downeast on Firewood and Wood Heating
Last post April 06, 2012, 10:46:33 PM
by downeast
Splitter review - Oregon 28 ton
Started by DeerMeadowFarm on Firewood and Wood Heating
Last post April 12, 2016, 02:12:28 PM
by DeerMeadowFarm
Countyline 40 ton splitter, 8 month review.
Started by Upstatewoodchuc on Firewood and Wood Heating
Last post December 26, 2021, 11:07:19 AM
by Upstatewoodchuc
