Author Topic: Using OWB for drying firewood?  (Read 1364 times)
Offline DaleK
  • Ooooooh, I'm a lumberjack and I'm ok......
« on: February 13, 2014, 09:30:22 PM »
With the wild demand for wood this winter here I'm starting to eat into wood I had put aside to sell NEXT winter so I'm looking for ways to speed up the process. Got excess capacity in my OWB which I only feed with the stuff I can't sell anyway and trying to think of the best way to use it. Any ideas/experiences?
Hud-Son Oscar 330
Wallenstein FX110
Echo chainsaws and a whole bunch of tractors
Offline leonz
Re: Using OWB for drying firewood?
« Reply #1 on: February 13, 2014, 11:53:57 PM »
Unless you have wad of money the other half does not
know about its not worth the effort even on a small scale
to even think about. It takes a lot work and money to
do this.
The lumber mills have the advantage of mill ends,
crap/reject logs and steam fired kilns fed with wood chips
and bark to dry thier firewood for the "romance bundles".
Splitting the firewood very small also helps in drying it.
Your forest eater is not up to the task.
Offline thecfarm
« Reply #2 on: February 14, 2014, 09:41:44 AM »
DaleK,would need a insulated building,than something to put the wood into,like a box,than something with wheels to put the cart onto,than something with forks to remove the box. Than need a way to keep the snow off any kiln wood,if it did not get sold at that point.
Offline DaleK
« Reply #3 on: February 14, 2014, 12:29:33 PM »
Got lots of old running gear around. Was somewhat thinking of a couple of insulated shipping containers, build wagon racks to fit nicely inside, load up one at a time and back it in. I have lots of old barn fans and about 30,000 sf of buildings to put the dry wood into, and a big old rad on a parts tractor that might make a good heat exchanger.
Hud-Son Oscar 330
Wallenstein FX110
Offline red oaks lumber
« Reply #4 on: February 14, 2014, 01:14:57 PM »
i have dried semi seasoned firewood for people in my kiln before. not my wood but theirs. results? not worth the effort, took way to long. the wood needs to be stacked so the air can easily pass thru the stack. sorry just my exsperiance :)
Offline CRThomas
« Reply #5 on: February 14, 2014, 04:27:45 PM »
I cut a ASh tree which is about a cord I split it put it in my shop turn the fan on my furnace on pilot light keeps the 20 x 20 building 60 degrees I check the next day at noon the end will be 8 to 10 percent I split a piece the middle will be 14 to 15 ready to burn. people ended up buying green wood would not burn so they buy Ash from me to burn the green wood. I do this 5 to 6 days a week. I go to the woods in the morning and I am back by noon. I cut one or two big Ash. If a Oak or Hickory gets in the way I cut them leave them in the woods for maybe cut disk for clocks. later
Offline r.man
« Reply #6 on: February 14, 2014, 10:45:00 PM »
Don't, know about the economics of having a kiln for drying firewood but it could do triple duty, drying lumber, drying firewood and heat treating wood products such as firewood or pallets. Many jurisdictions now require heat treating for wood products that are moved out of the area.
Offline CRThomas
« Reply #7 on: February 25, 2014, 04:23:32 PM »
If your going in to real business my bundled firewood business I have about $250.000.00 in my set up. I sell bundled firewood year round I don't switch from firewood to mowing grass. I don't sell when I need a case of beer or a carton of cigaretts. I sell for a living hope I didn't hurt any bodys feeling but that's the way it is. I am 73 so I have to make thing easy for me and take care of my customer
Offline NWP
    • Nicholson Wood Products LLC
« Reply #8 on: February 25, 2014, 07:29:48 PM »
A quarter million dollar setup and you cut one or two trees a day and stack it in your shop to dry?
1999 Blockbuster 2222, 1997 Duratech HD10, 2021 Kubota SVL97-2, 2011 Case SV250, 2000 Case 1845C, 2004 Case 621D, John Deere 540A, 2011 Freightliner with Prentice 120C, 2012 Chevrolet, 1997 GMC bucket truck, several trailers, and Stihl saws.
Firewood drying ?'s
Started by Timberwerks on General Board
Last post July 13, 2004, 08:03:51 PM
by bennelson
drying firewood
Started by Timberjack_395XP on Drying and Processing
Last post April 22, 2014, 08:35:44 PM
by glassman_48
Drying firewood
Started by John Vander on Firewood and Wood Heating
Last post February 18, 2013, 07:39:16 PM
by drobertson
drying firewood
Started by trapper on Firewood and Wood Heating
Last post April 28, 2020, 07:14:01 PM
by bluthum
